Iwata Eclipse malfunction help
    September 2010
Posted by Don KC on Tuesday, April 12, 2011 9:57 PM
Guys,
I've used an Iwata Eclipse HP-CS for a few months and have been very happy with it.  However, I picked it up tonight and it acted strangley.  First, the drops of water in it leaked straight out of the nozzle.  Then that stopped and when I pushed to spray, nothing came out of the nozzel but the water violently "boiled" out of the cup.  I disassembled it.  It's clean.
Looking at the diagrams, I'm wondering if I'm missing a part, specifically the nozzle (#4 in the diagrams of the owners manual).  The blow up has parts for several eclipse models and I can't tell for sure if it's supposed to have one.  Did I somehow lose this part?  Don't want to buy a part at hobbylobby I don't need.  Any confirmation would be appreciated.
-Don
    August 2005
Posted by Phil_H on Wednesday, April 13, 2011 12:16 AM
The nozzle (part #4) is common to all the models shown in the exploded diagram. If it is missing, then yes, you have a major problem and it will need to be replaced before your airbrush will work. If you need to buy a replacement nozzle, it is essential that you buy the correct size for the needle you currently have (I believe the "standard" nozzle on the CS is 0.35mm)
If it is present and you are getting blowback into the paint cup, it suggests that the head cap (part #5) has not been tightened sufficiently. I strongly suggest loosening the needle chuck and withdrawing the needle slightly before attempting to tighten the head cap to avoid potential damage to the needle and/or nozzle. After tightening, re-seat the needle.
    April 2011
Posted by Unreality on Wednesday, April 13, 2011 12:23 AM
I have the same airbrush...very nice quality. And yes, you need the nozzle (part #4). Without it, the paint will leak and the air will escape in the fastest way possible: out the top cup. It's easy to lose the part when cleaning or assembly because unlike many airbrushes, the Eclipse nozzle just "sits" in there and doesn't screw in.
For the HP-CS, you're using the .35mm nozzle, which is brass with a tapered steel tip (not the .5mm nozzle) and it is quite expensive to replace. You may want to double check your area before throwing down the $25 or so to replace it.
You're looking for the one on top: http://shop.ebay.com/?_nkw=iwata%20eclipse%20nozzle&rvr_id=224731750978
PDF higher-rez diagram: http://www.iwata-medea.com/images/iwata-pdf/Eclipse%20IM.pdf
Action Fleet Unlimited: Star Wars models, customs, toys, techniques, and scale lists (with a few non-SW models thrown in)
Cheers
    January 2008
Posted by somenewguy on Wednesday, April 13, 2011 12:08 PM
Damn. That's almost exactly what happened with my badger Renegade Velocity just now. Must be a pandemic.  Not sure what's wrong with mine. Probably essentially the same problem. Hope yours is fixed soon.
At the end of the day one's work may be completed but one's education never!
    September 2010
Posted by Don KC on Wednesday, April 13, 2011 6:35 PM
Thanks for the advice, guys.
Must have lost it during cleaning and didn't realize it was gone.  Will do a [fruitless] search and then off to hobby lobby this weekend with my 40% off coupon in hand!
thanks again!
