I'm not sure how that lubricant would work.
The reason people recommend lubricants like Super Lube, Badger Needle Juice and Airolube is because they will not affect any paint sprayed through the airbrush. I am not sure if that lube you have would affect it or not.
Some people use a very small amount of Vasoline petroleum jelly but I would be real careful with it as too much could affect the paint.
To lube the trigger alone an inexpensive lube for that is glycerine that can be found at a drug store. I have not tried it but I have heard it works well.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
