Model Master enamel spray paint on wood?
    July 2009
Posted by Blackbelt2 on Tuesday, May 3, 2011 7:58 PM
I am building a diorama of the Blue Angels C-130 Fat Albert. I am about to finish the base and I have a painting question. The wood trim around my base is pine. I would like to paint it in white, gold and blue. Can I use Model Master spray enamels on wood after priming or are these enamels only for plastics? I wanted to go white, gold and blue on the wood trim. Could I use Tamiya acrylic spray paint?
Posted by Don Stauffer on Wednesday, May 4, 2011 9:30 AM
Yep- I use Testors enamel on wood frequently.  Takes several coats of prime to fill grain.  By the time you have grain filled, you will have a good prime coat on wood that will take enamel fine.
You can use a sealer if the wood is very fine grain like basswood. I make a sealer from clear polyurethane varnish thinned 50:50.  Sealer cuts down on number of prime coats needed.
I use Krylon primer. It dries fast, about 20 minutes, so it doesn't take long to get three or four coats of prime on.  Sand between coats, of course.
    July 2003
Posted by zokissima on Wednesday, May 4, 2011 9:34 AM
You can use the MM spray enamels just fine. I've done it many times on wood, with no issue. Prime first if you can. Alternatively, as you stated, you can also use Tamiya, no problems.
    July 2009
Posted by Blackbelt2 on Wednesday, May 4, 2011 10:18 AM
Thanks Don, I appreciate the help.
Karl
    July 2009
Posted by Blackbelt2 on Wednesday, May 4, 2011 10:20 AM
Thanks very much for your help!
Karl
    July 2008
Posted by jeffpez on Wednesday, May 4, 2011 12:45 PM
I agree with the others about the need to seal the wood but you may also want to consider using something other than pine because it's both porous and has a strong grain pattern that's hard to hide under paint. For a fairly cheap althernative try poplar which takes paint very well and is readily available everywhere including the home centers. Then seal, sand and paint for great results.
    August 2005
Posted by EdGrune on Thursday, May 5, 2011 7:03 AM
jeffpez
sity
As long as you're looking at other woods at the hardware store,  take a look at MDF - Medium Density Fiberboard.   This wood product has absolutely no grain.  It cuts and machines with typical woodworking tools, and it finishes to a glass-smooth paint finish with just a couple of coats of spray.  I'll use hardware store spray lacquer, spray and sand between coats.
    August 2006
Posted by HawkeyeHobbies on Thursday, May 5, 2011 8:53 AM
There are wood sealers used in the R/C side of the hobby for those who build with wood.
You also probably already have another very good sealer on your bench...FUTURE.
The goal is to seal the wood pours/cells so they don't absorb the cover coat, just as one has to prime a brick wall to seal the concrete before applying paint to it.
Gerald "Hawkeye" Voigt
Posted by Don Stauffer on Thursday, May 5, 2011 9:13 AM
jeffpez
I'd second this.  While Basswood is particularly good for making models (scratchbuilding), Poplar is almost as good, and for bases and such it is fine. It is considerably cheaper than basswood and many home improvement stores now carry it, whereas you need to go to a hobby shop or wood carving shop for basswood.
When making solid hull ships I use poplar because that much basswood is a significant cost.
    July 2009
Posted by Blackbelt2 on Friday, May 6, 2011 2:06 PM
I do have Future. I didn't think of using it on wood. Thanks for the help.
Karl
