Painting fine raised detail?
    October 2007
Posted by Milairjunkie on Wednesday, May 25, 2011 4:20 AM
Has anyone got any tips for painting fine raised detail like fuel & hydraulic lines in 1/72?
I have tried using a fine brush, edge onto the detail, but the results are variable to say the least........ I would mask & airbrush, but the molded hold down brackets on fuel lines & the like make masking pretty much impossible.
Any advice appreciated.
    August 2006
Posted by HawkeyeHobbies on Wednesday, May 25, 2011 9:21 AM
Use a technical pen. I use 00 or even 000 sizes. These are available in various colors which use water based inks or India Inks.
http://hawkeyes-squawkbox.com/2010/02/14/detailing-pens/
Gerald "Hawkeye" Voigt
    May 2011
Posted by AceHawkDriver on Wednesday, May 25, 2011 9:21 AM
depending on the situation i've had luck with drybrushing some detail as you mentioned.  I'm not sure if this will work in every case but it has before.  You just want to make sure you're building up the color on your detail pieces a little at a time, rather than all at once.  hope it helps!
Peace through superior firepower.
Brian
    March 2010
Posted by Hercmech on Wednesday, May 25, 2011 9:37 AM
I have tried detail pens and have had good luck with the darker colors, and I have also drybrushed to great effect.
13151015
    October 2007
Posted by Milairjunkie on Wednesday, May 25, 2011 10:13 AM
I was about to say "seen that...................T-shirt", as I often use Rotring steel nibbed Technical pens (0.25 or thereabouts) for small details, they are great for cockpit detailing & filing in recessed detail, but don't work to well on long continuous raised things like fuel lines as they naturally want to slip of the raised detail onto the panel below.
But now I'm thinking that that the detail pens that you all mention are of the fiber tipped variety, which unlike the Rotring actually have an edge to them.............. must give them a try - thanks all!
Any other suggestions or black magic on the subject appreciated.
Posted by Don Stauffer on Wednesday, May 25, 2011 2:16 PM
I use a toothpick, the round sharp edge (double edged) kind.  The way I use it is this- I shake the bottle as one normally would, take off the cap, and lay the cap down upside down on the bench top.  A film of paint will be in the cap, just thick enough to give the right amount onto the end of the toothpick. I dip the toothpick in the paint, then paint with it like a brush.  Because not much paint wicks into the wood, you cannot paint nearly as long of a line as for a fine brush, so you have to re-dip quite frequently.  But toothpicks are cheap and I use them for a lot of things, so I keep a supply handy.  If I get too much paint on the tip I daub it once onto the back of a business card- I always keep a supply of old business cards near my workbench- they are useful for a number of painting and gluing operations, such as dry brushing (daub brush on card to spread some paint on the card then pick up small amount with brush).
    October 2007
Posted by Milairjunkie on Thursday, May 26, 2011 8:35 AM
Cheers Don!
I wouldn't be without cocktail stick's (what we call them here anyway) & do use them for painting buttons & what not - but hadn't thought about using them side on for this sort of stuff.
It's quite amazing the uses they have (or some people can find for them);
    February 2007
Posted by mitsdude on Friday, May 27, 2011 2:34 AM
I use a small flat file or sanding stick and lightly run it along the raised detail. Only works if the undercoating is a little darker than the top coat.
The metal file worked best as I used its weight while running it along the detail.
 I used this method on a B-24 that had a dark gray primer and silver top coat.
    February 2021
Posted by Truckindude on Saturday, February 27, 2021 10:47 PM
I saw a video where the painter thinned the paint and dropped it into the recessed areas and the paint flowed into it. I would like to know if it would work with acrylic paint.
