How can I remove paint and Laquer?
    May 2011
Posted by AdrianUK on Saturday, May 28, 2011 5:14 PM
I had a major problem after finishing my Mustang GT500 model, basically I was "advised" to use an actual car laquer to finish it off,, unfortuneatly I over did it and it melted the decals,,, now I am wondering if there is any way I can remove it and the paint without damaging the plastic?
I seem to recall something that would remove paint and not melt the frame, but cant recall it's name or if it would remove laquer as well ?
Any and all advice welcomed :)
On The Bench.....  Tamiya Lancaster
Started PreProduction...   Tamiya Mosquito
In The Hanger...  , HobbyCraft JU88-A4, Mobieus Ironman MK 3, Revell HE 111, , Revell B-17 Memphis Belle, , Dragon ME 262, Arado Ar 234, Eduard Tempest Mk V, Airfix Model club Me109 Ltd Edt, Academy F15 Iraq Freedom. Airfix 1:24th Mosquito
cml
    March 2007
Posted by cml on Thursday, June 2, 2011 1:00 AM
I know Windex will remove acrylic paints without too much issue - but it might not be strong enough on the lacquer.
Another product which i've used here in Australia that seems to remove everything without melting plastic is a product call "Goo Remover".  It's found in the cleaning aisle of supermarkets and is touted as being able to remove things such as chewing gum from carpet and stains off walls.
It has a very strong orange/citrus smell.
I've found it will cut through paints etc with no trouble - but again, can't guarantee it'll work on automotive lacquer.
Hope this helps.
Chris.
Chris
    May 2009
Posted by Pawel on Thursday, June 2, 2011 2:01 AM
Two things that are normally used to strip paint are:
1) Brake fluid. There are paints that are resistant to it, but it has the big advantage it's harmless for clear parts.
2) NaOH - found in stuff used to unclog the drains. Very agressive, more so against paints containing aluminium (metalics). May fog clear parts.
Some people also recommend oven cleaners - this I didn't try myself. Anyhow, there's a lot of stuff available. But a messed up paint job is always a pain... Good luck fixing it, have a nice day
Paweł
www.vietnam.net.pl
    January 2003
Posted by TomZ2 on Thursday, June 2, 2011 12:22 PM
cml
Here a similar product is called “Goo Gone” by Magic American Corporation. I have used it to in cases where there was something ‘chemically inappropriate’ (spelled ‘it’s melting!!!’) going on.
But I’d also like to mention “Goof Off” by Lilly Industries, Inc. It’s available at paint & hardware stores. It will ABSOLUTELY remove dried latex paint.
For lacquer I’d try “Easy Off” oven cleaner. In extreme conditions, there’s Naval Jelly.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    May 2011
Posted by AdrianUK on Thursday, June 2, 2011 1:17 PM
Thanks for the help,, I managed to get the lacquer  off by using oven cleaner for 24 hours,, that turned it brittle so it cracked off,, then another 24 hours in oven cleaner for the paint to come off.
cml
    March 2007
Posted by cml on Monday, June 6, 2011 6:59 AM
Excellent, glad to hear you've had success.
Chris
