How to adjust pressure on Iwata Smart Jet?
    April 2011
Posted by Fatalgrace on Sunday, June 12, 2011 2:49 PM
I have an Iwata Smart Jet compressor. When try to lower the psi and unscrew the release valve at the bottom of the water trap, the pressure goes down but the machine constantly runs. It seems as if Iwata's solution to lowering the psi is to just let the air leak out? In essence, the "smart" part of the smart jet (the auto on/off) no longer works, and it becomes just loud.
Is this right?
Thanks
    October 2007
Posted by Milairjunkie on Sunday, June 12, 2011 3:44 PM
The standard Smart Jet has no receiver (air tank), so to produce air pressure the motor has to run & the only way to adjust the output pressure on a compressor without a receiver is to bleed some away from the output. To quote Iwata;
"Bleed valve airflow adjustment to lower air pressure"
The auto on/off still works, but only shuts off the compressor when there is no demand for air, it has nowhere to store air, so if you request air - the motor must run. Regards to it getting louder,  that will be the air that's bleeding out when a lower pressure is set.
I don't really get the whole "Smart Jet" deal as a selling point - as far as I can see, it's just an auto on/off switch which you would expect on any decent compressor! I'm not knocking Iwata or the "Smart Jet" feature as it's a perfectly good product, but in this day & age I really don't see whats unique or special about it?
So, in short, yes - it sounds about right.
    April 2004
Posted by keilau on Sunday, June 12, 2011 3:53 PM
Fatalgrace
Is this right?
Thanks
Yes, according to the Iwata manual, the Smartjet does not have a pressure regulator. Does yours come with a manual? If not, here is the link.
1. When you first hook up your airbrush to your compressor and depress the trigger of your airbrush, the pressure that registers on your gauge is called your “working pressure.” Your working pressure can vary depending on the size of your airbrush’s nozzle. The smaller the nozzle size, the higher your working pressure. An average nozzle size of 0.3mm will expend a working pressure of approximately 25-28 psi with the Smart Jet.
2. You cannot increase your working pressure, but you can decrease your working pressure by using the air adjustment knob to open the bleed valve.
3. Adjust the air pressure by turning the air adjustment knob toward the + or – while spraying air from the airbrush.
4. When you open the bleed valve with the air adjustment knob, the Smart Jet’s Auto Shut-Off will disengage and cause your Smart Jet to run continuously. This only happens when you regulate the pressure to lower than the working pressure.
5. When you twist the air adjustment knob all the way back toward the +, it closes the bleed valve and re-engages your Auto Shut-Off feature.
You will need to move up to the Smartjet Plus or the Smartjet Pro to get the pressure regulator.
    April 2011
Posted by Fatalgrace on Sunday, June 12, 2011 5:27 PM
Thank you so much for the quick replies!
If I buy a diaphragm regulator will it work with the auto/on/off?
Thanks
    April 2004
Posted by keilau on Sunday, June 12, 2011 5:42 PM
Fatalgrace
No reason that the diaphragm regulator will interfer with an auto-on-off switch. The auto-on-off switch sensor is upstream of the regulator.
I have one with my Paasche DA400. The auto-on-off works just fine. Good luck.
    April 2011
Posted by Fatalgrace on Monday, June 13, 2011 8:22 PM
Added a diaphragm regulator today. smart jet on/off works just fine even at extremely low PSI.
thanks all for input!
