Painting a propeller with enamels
    March 2010
Posted by stcat on Wednesday, June 15, 2011 9:50 PM
I've seen articles in various mags about creating the light orange/dark wood grain for WWI propeller's.  But the authors invariably use acrylics.
Can anyone share their technique using something like Testors Model master series?  What colors do you use?
    October 2010
Posted by The Navigator on Wednesday, June 15, 2011 10:08 PM
I made one once. I used MM paints but covered it with Tamiya clear yellow. The clear is what makes it look right. Maybe try mixing some yellow in the clear gloss and try it out . Hope this helps
P.S.- why don't you want to use the clear yellow?
I have many books and my Lair smells of rich mahogany!!! Stay thirsty my fellow MOJOs!
    March 2010
Posted by stcat on Thursday, June 16, 2011 8:11 AM
No problem with using clear yellow.  I will admit to some trepidation with non-emamels as I haven't sprayed them before (I know, i know, get out of my comfort zone).
But there is a clear yellow enamel?
I'd like to do in 1:48 what Wing_nut has done here:  /forums/t/138897.aspx
Posted by Don Stauffer on Thursday, June 16, 2011 9:01 AM
I use Testors cream, yellow, and brown.  I add the yellow to the cream to get the main color I want, then apply it.  Then drybrush  the brown for grain streaks.
    October 2010
Posted by The Navigator on Thursday, June 16, 2011 9:43 AM
Acrylics can be a little tricky, you have to watch the air pressure. If it's too high, the paint dries as it's leaving the brush. What are you using for air, can or compressor?
    December 2005
Posted by Schnord05 on Thursday, June 16, 2011 9:44 AM
Testors 1141 "wood" (1/4 oz. bottle) with burnt umber artist's oil paint brushed over it.
Lindberg 1/4 scale Stearman. More at the blog:  http://hawxblog.typepad.com
    March 2010
Posted by stcat on Thursday, June 16, 2011 11:27 AM
I'm using an Iwata compressor and airbrush.  Revolution model.
    April 2005
Posted by wing_nut on Wednesday, June 22, 2011 3:19 PM
stcat , I am trying to remember exactly what I did foe the prop, especially since I had to redo it and changed the method 2nd time around. It's harder than you think on lt because of the many many different things I tried for the plywood they all are a blur at this point.
I am pretty sure that was Tamiya wood masked off and the MM enamel Military Brown. The grain is done with Windsor-Newton Winton Oil #35 Raw Umber.  Because this would have removed the brown I have to coat is with a clear flat acrylic.  Easiest way is to just use all acrylics of the base but i didn't have any brown.  Wipe on a thin film of the oil.  This was then streaked with a piece of a Scotch Brite pad.   Several coats of Future for the gloss.  I didn't use clear yellow coz since the props broke and were changed out so often there was no time for the shellac to yellow like on the fuselage.
Marc
