recomend a new airbrush
    June 2010
Posted by montague on Monday, June 27, 2011 4:06 PM
Hi!
Can anyone suggest a good airbrush for fine detail and camo work that has very little overspray. I am using a Harder and Steenbeck Ultra with a .2mm needle set but still cannot get away fron bothersome overspray regardless of paint viscosity or pressure. I was looking to spend in the $100.00 range and wanted a gravity feed brush. I use acrylics only.
Thank you in advance!
Posted by BaBill212 on Monday, June 27, 2011 4:42 PM
I'm a die-hard Paasche user. I've had my single action H model for 30 years. I also have a double action VL. I've never had an issue and I use acrylics exclusively as well.
Not sure why you are getting so much overspray though.....  is the tip damaged?
Enjoy the ride!
    November 2008
Posted by iraqiwildman on Monday, June 27, 2011 4:47 PM
I would stick with a Badger brand, like a 105 Patriot or the new Renegade Krome. They have great customer service and a lifetime warrenty.
Tim Wilding
    February 2011
Posted by randypandy831 on Monday, June 27, 2011 5:21 PM
Iwata HP-CS........................done!
tamiya 1/48 P-47D $25 + shipping
tamiya 1/48 mosquito $20+ shipping
hobby boss 1/48 F-105G. wings and fuselage cut from sprue. $40+ shipping.
cml
    March 2007
Posted by cml on Monday, June 27, 2011 5:52 PM
Badger 100LG works good for me and fits two of your requirements, ie: gravity fed and under $100.
How much overspray are you getting?
Chris.
Chris
    April 2010
Posted by Ripcord on Monday, June 27, 2011 6:48 PM
Badger Anthem!
Posted by BaBill212 on Monday, June 27, 2011 7:04 PM
3 Badgers, 1 Iwata, 1 Paasche
How can you go wrong?
Enjoy the ride!
cml
    March 2007
Posted by cml on Monday, June 27, 2011 7:07 PM
BaBill212
Hehe, Ditto Big Smile
Chris
    December 2009
Posted by brickshooter on Monday, June 27, 2011 9:17 PM
montague
Hi!
Have you thought about changing the angle of your spray?  Instead of spraying at 90 degress, spray at a 70 degress angle.   Since you're using a .2 mm needle, you'll not get that much of a modulation difference in the paint laid down.   I generally do this when drawing out a camoflauge outline.    Then I spray at a 90 degree to fill it.
    March 2010
Posted by Hercmech on Monday, June 27, 2011 9:26 PM
iraqiwildman
Ditto However you have a very nice A/B now and I don't know if buying a new one will solve your problem. Maybe try lowering your pressure or chaning up the paint thinner ratio a little. It's your money but I would experiment a little more to see if I could get it to work.
13151015
    February 2011
Posted by randypandy831 on Monday, June 27, 2011 9:49 PM
lowering the pressure should do the job. try not to thin as much as it will make it run.
    September 2010
Posted by Marine Sniper on Monday, June 27, 2011 10:21 PM
BaBill212
I have 14 Badgers so make that 17 Badgers, 1 Iwata, 1 Paasche. Big Smile
    April 2004
Posted by keilau on Tuesday, June 28, 2011 3:58 AM
montague
[/quote]
Ditto
It will be hard to find an airbrush under $100 that may have less overspray than the Ultra with 0.2 mm nozzle. I don't have this airbrush, but I cannot image the 3 Badgers suggested to have less overspray than the Ultra. The Krome may be similar, but the other 2 will have a lot more overspray.
It may not be the airbrush, but a matter of how you use it.
    June 2010
Posted by montague on Thursday, June 30, 2011 3:17 PM
Hi!
To answer many questions, The needle is not damaged, this occurred regardless od pressure and viscosity, changingthe angle helped some. I did have an opportunity to purchase an Iwata HP-CS and I am sure it will perform well.
BaBill212 suggested a Paasche H and said he had no problems. I had one stuck away in a drawer that I had cut my teeth on tears ago. I put the small neele set in, set the perssure to 30 psi and used a cup attatchment and was stunned at the fine lines and no overspray! Thank you all for the advice but especially BaBill212 for the reminder of the Paasche H! Problem solved!
Selling my Harder and steenbeck ultra and Iwata neo on ebay. Look up amazingphil66 to see them.
    June 2010
Posted by DoogsATX on Thursday, June 30, 2011 3:31 PM
Awesome that the H is working out for you!
It's amazing how different airbrushes seem to work for different people.
Personally...out of my Iwata HP-C Plus, HP-CS, Badger 105, Badger Renegade, Paasche H and H&S Evolution, the H&S is my first love. Strangely, I've had nothing but frustration with the Badger 105 Patriot, which a ton of people seem to really love.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
Posted by Bish on Thursday, June 30, 2011 3:40 PM
cml
Chris.
You lucky swine. I currently have a 150 but want to get a 100LG. They are currently £115 in Hannants, works out at 172 AUD.
I would deffinatly say a badger.
Posted by BaBill212 on Thursday, June 30, 2011 4:15 PM
Mike,,,,,   14 Badgers!?              Octo-Airbrushing?
Enjoy the ride!
    September 2010
Posted by Marine Sniper on Thursday, June 30, 2011 10:01 PM
BaBill212
Edward airbrush hands! Big Smile
cml
    March 2007
Posted by cml on Thursday, June 30, 2011 10:31 PM
Bish
 cml:
Chris.
Hehehe,  I actually bought it off Ken Badger - can't recall exact price, but was unbelievably cheap compared to the price of airbrushes here in LHSs.
I use it almost exclusively now - also have a Paasche H, but it's too troublesome to clean compared to the 100LG.
I can't rave about it enough Stick out tongue
Chris.
Chris
