Oil Paint Sets
Oil Paint Sets
Posted by wjbwjb29 on Thursday, June 30, 2011 6:46 PM
Hell;
Anyone know of a fairly good set of oil paints that wont break the bank. These will be used primarily for figure painting and washes. I want to try my hand at mixing colors.
Bill
On the Bench:   Trumperter Tsesarevich on deck Glencoe USS Oregon
    June 2010
Posted by montague on Thursday, June 30, 2011 10:13 PM
Hi!
The best for military and figure painting is the  MIG productions 502 Abteilung range, but they are not cheap. If you built up your collection over time it may be better. Hobby Lobby also has sets that they sell at a reasonable price. If you check their website the periodically run 40%off coupons too that you can use.
    April 2008
Posted by smeagol the vile on Thursday, June 30, 2011 10:45 PM
Go to michaels or whatever the local one near you is called.  I found mine for like $8, if that, might have been 6$  It came with like 8-10 colors in little tubes, was a PERFECT starter set, I was still using it.
Posted by wjbwjb29 on Friday, July 1, 2011 5:43 PM
Got a 12 tube set for 5 bucks plus I used the 40% off coupon. I think thats enough oil paint to last a few years,
Thanks for the heads up.
Bill
    April 2008
Posted by smeagol the vile on Friday, July 8, 2011 11:58 AM
Your very welcome.
If I may make a suggestion.  I KNOW from experiance that if you start using those often like I did you will run out of two primary colors quickly, one bring white, the other being a dark, but not reddish brown.  What I did was got the 40% of coupons, bought the most expensive and biggest tube of white I could get and a few medium sized browns of different colors.
If you ask why brown... well brown just gives a nice... rounded feel when mixed then black does for darkening, black really makes colors harsh when mixed.
    February 2010
Posted by EBergerud on Wednesday, September 14, 2011 3:29 AM
I've got to post about this. In brief, if you want to make washes or filters you want a "student grade" oil paint of which Abteilung is simply the most expensive. Reeves at Micheal's or Blicks sells for about $15 for 12 little tubes and it'll make a lot of washes. Whoever said buy extra white is right.
If you want to mix paint then I'd stick with real artist grade oils. Artist grade oils have "pigments" combined with linseed oil. The pigments can be chemical or natural: some are extremely expensive, others much less. (Let me tell you: if you get a series 4 blue or red from a good maker, the color will explode - it's really something. Also enough to last a modeler about five lifetimes.) Luckily artist grade white is cheap. Student grade have oils that are mixed with "hues", not pigments. The difference, simply put, is that student grade oils have paint inside the paint. Artist oils are almost closer to using weathering pigments. The reason artists buy artist grade (assuming they can afford it) is that the pigments are more powerful and thus you get better coverage and, if you want it, truer and deeper colors. The other reason is that pigments mix together very well. Hues don't. Try mixing modeling acrylics together - if you don't know what you're doing you'll end up with something muddy really fast. Much less likely to happen with pigment based paints.
Anyway, if you want washes get a student grade oil - there are lots of brands. If you want to mix paints, and painting figures might well reward that, get artist grade primes (red, yellow, blue, green [green's cheating, but do it] a black and a big tube of white. If you're lazy, as suggested above, something like burnt umber is very nice. Color mixing is an absolute gas and is an art of its own. Use only very small amounts - dole it out with a toothpick. If you're painting with an oil, watch thinner use. There are "mediums" available that are also oil based to alter the nature of the paint, (change its consistency, make it matte, satin, gloss: about anything really) but too much thinner will break down the chemical glue that holds the paint together. Talk to an art shop guy about thinners. I prefer mineral spirits but know some artists that insist on turpentine.
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
