Good spray booth recommendations?
    September 2010
Posted by Don KC on Thursday, July 14, 2011 6:22 PM
Wife told me to go get a spray booth after my last session resulted in an olive drab hard wood floor.
I use almost only acrylics and don't have a way to do an exterior vent so I'd like one that has filtering capability without an exterior vent.  I'd like to spend less than $250.
Any suggestions or recommendations?  Any place sell them cheaper than others?
    January 2003
Posted by TomZ2 on Thursday, July 14, 2011 7:00 PM
I got good results with ModelExpo’s Compact Spraybooth, Exhaust Hose, Filter Combo #HSE420PRO
BUT there’s an even better deal for just $209.99, the “Super Saver Combo” version:
  1. HS08AC-SK - Mini-Compressor & Double Action Airbrush Set
  2. HSE420 - Compact Spray Booth
  3. HSE420H - Exhaust System
Use offer code W383.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    September 2010
Posted by Don KC on Thursday, July 14, 2011 7:36 PM
Thanks, Tom but what's the website?
Also is this going to work okay for using acrylics without connecting it to an outside exhaust portal?
    January 2003
Posted by TomZ2 on Thursday, July 14, 2011 8:29 PM
You’re pulling my leg, aren’t you?
http://www.modelexpo-online.com/
or just Google “modelexpo”.
The idea is to connect the spray booth (which folds exceptionally nicely for storage, BTW) to the exhaust hose and route it through an opened window (just a crack) via the flattened nozzle.
    April 2004
Posted by keilau on Friday, July 15, 2011 8:31 PM
Don KC
Artograph 1520 Compact Spray Booth may work for you and it is well within your price range. The difference between Artograph and other is the fact that Artograph designed theirs with carbon filter so that it can be used without external connection. But the consumable could be expensive over the long run.
(I do not have one and cannot comment on its filter effectiveness.)
    January 2013
Posted by Planeguy on Thursday, February 21, 2013 1:44 PM
I HAVE A SIMILAR  SPRAY BOOTH THAT IS AVAILABLE IN THE U.K.
THE  MAIN PROBLEM IS THAT THE FOLDING DOORS ARE MADE WITH POLYSTYRENE ( ITHINK )  WHICH CRAZED ON USING WHITE SPIRIT SOLVENT ,  I USE HUMBROL ENAMELS.   MY SOLUTION WAS TO LINE THE INSIDE COMPLETELY WITH THE POLYPROPYLENE  CUTTING BOARDS AVAILABLE IN SUPERMARKETS VERY CHEAPLY .  IT IS NOW NO PROBLEM TO USE ANY SOLVENT  ,( INCLUDING ACETONE  WHICH ATTACKS MOST PLASTICS )  AND I SPRAY THE SURFACES WITH A FINE WATER MIST JUST BEFORE SPRAYING TO CUT DOWN ANY DUST PROBLEMS. WORKS GREAT.  ALSO THE OFF CUTS ARE VERY USEFUL FOR MIXING EPOXY RESINS ,FILLERS ,ANYTHING REALLY!
THEY MAKE GREAT SPREADERS FOR FILLERS TOO ,JUST CUT TO SHAPE. LOTS OF OTHER USES!!
    February 2011
Posted by Hokey on Friday, February 22, 2013 8:17 AM
TomZ2
Any idea where to get replacement filters? Or substitute?
Posted by Don Stauffer on Friday, February 22, 2013 9:14 AM
I do not vent my spray booth in the winter.  Acrylics make almost no odor with a decent filter, and even enamels have the odor greatly reduced with a good filter.  I make my own booths, but whether homemade or purchased, a good filter goes a long ways on making spraying tolerable even without a vent.
    October 2008
Posted by P mitch on Friday, February 22, 2013 9:26 AM
I have the same booth your talking about here and with Acrylics the filters work well enough, enamels etc I always vent to outside, I only vent acrylics outside in the warm months. With enamels I will still wear a mask just to be safe, I generally think if you can smell it the first time you need to wear a mask
In over a year I haven't changed the filter, I got s spare when I baught mine anyway
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    January 2003
Posted by TomZ2 on Friday, February 22, 2013 11:55 AM
Hokey
TomZ2
ModelExpo’s extra filter for HSE420 (http://www.modelexpo-online.com/product.asp?ITEMNO=HSE420F) $14.99
    March 2012
Posted by Chili on Friday, February 22, 2013 2:22 PM
The portable spray booth that many are talking about can be purchased for as little as $79.00 on the web. Just google it and you'll see prices for the identical booth(though often relabelled ones) from $80-200. Many now come with the 4 ft. hose to window attachment that sometimes sells for $25.00. Let your fingers do the walking.
    July 2012
Posted by littletimmy on Friday, February 22, 2013 5:48 PM
In a pinch you can substitute Home heating filters. you can get them in most hardware stores for about 5 bucks. Yes i know...... there not the same thing. But I said in a pinch.........
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    December 2011
Posted by Chrisk-k on Saturday, February 23, 2013 11:22 AM
I have a ModelExpo booth. I always wondered about the functionality of the filter. I mean, the booth exhausts the air infested with paint particles to the outside. Then, why is the filter needed?  To protect outdoor air?
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
Posted by Don Stauffer on Saturday, February 23, 2013 11:23 AM
littletimmy
I second the idea of furnace filters in homemade booths. I used to use auto air filters but the furnace filters work much better and are at least as cheap if not cheaper.
