Primer
    August 2011
Primer
Posted by Michigan_Duck_Slayer on Friday, August 5, 2011 5:15 PM
As with most of the posts & replies that I've read on here (and other sites) over the last few days, it sounds like everybody is priming everything.  Since being out of the hobby for almost 30 years, the only priming I know of was in the car industry! (try not to laugh too hard!)
I am no where close to being a professional modeler and got back into it for the fun, so my question is...
Is it really neccesary to prime everything you build and if so, what, exactly, does the priming function achieve?!?!
Any and all info is greatly appreciated!  THANKS in advance,
--JIM--
    October 2008
Posted by P mitch on Friday, August 5, 2011 5:53 PM
If your adding photo etch parts and resin bits then you need to prime to give everything the same colour to start from. Primer will also give the pain something to grip onto and give better coverage. I use automotive prime for most models as its cheap and gives good coverage.
Many better modellers them me will prime, then pre colour, then outline panels but I just dont have the time to go that far.
Hope that helps
Pmitch
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    January 2003
Posted by TomZ2 on Friday, August 5, 2011 5:57 PM
The advantages of using a primer:
  1. Providing a neutral background —
    essential when applying light colors over dark plastic (or metal, especially PE).
  2. Showing up flaws in the assembly.
  3. Giving the overcoats something to “bite”.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
Posted by Don Stauffer on Monday, August 8, 2011 9:47 AM
I use a rattle can primer, and paint whole sections of the sprue at once, so it isn't that big a job.  Priming never hurts, it only helps.  Why risk having to refinish a paint job?
I used to use Krylon sandable primer- other modelers recommended it and it worked.  However, Krylon has altered and renamed their primer a lot recently, and the changes are not for the better. I am looking around for a better, consistant primer and may return to auto primers like Duplicolor primer in spray cans.
    August 2011
Posted by Michigan_Duck_Slayer on Monday, August 8, 2011 11:53 AM
Once again... WOW!!
Thanks to all you guys for the great info!!  I guess I'm off to the store to find some primer!!
Posted by BaBill212 on Monday, August 8, 2011 12:14 PM
There are some items that I waive the priming,,,  but for the most part, I do use a primer.
All the reasons mentioned make it, almost always, a plus.
Good luck with it Jim,, and hope to see some of your work / pictures
Enjoy the ride!
    August 2011
Posted by GreenThumb on Monday, August 8, 2011 6:44 PM
I rarely use primer.
    April 2009
Posted by Cadet Chuck on Monday, August 8, 2011 6:53 PM
I use either Gunze Mr. Surfacer primer, or Tamiya fine surface primer in rattle cans.  They seem to fill up and hide minor scratches and imperfections in putty sanding.  Be careful and spray lightly, it's easy to overload it, the way that stuff comes out of the can.
    August 2011
Posted by Michigan_Duck_Slayer on Tuesday, August 9, 2011 4:35 PM
Thanks for all the additional comments!  I have never used any type of primer, I guess, because I never thought that I was at that "level" in the hobby.  I have always just brushed on my colors, except for a few pieces of armor that I airbrushed camo patterns on back when I was 15 or so.  The airbrush was a friends and I remember contemplating getting my own, but I think that the interest in girls back then over-powered the hobby and the airbrush idea fell to the wayside!
 I think I will try priming my next piece, Tamiya's M-20 Armored Utility Car.
