airbrush cleaning
    October 2010
airbrush cleaning
Posted by Warmuncher on Saturday, August 6, 2011 10:31 AM
Hi,
I am new around these parts.  I am also quite new to the airbrushing world.  I picked up a Badger Cresendo 175 a few months back.  It's a nice little airbrush for what I'm using it for.  I do clean all of my parts after every use however the there is always material left clinging to the parts after every use and cleaning.  The build up is becoming a problem.  I was watching a video where the host said that he uses an Ultrasound machine to clean his brushes though he failed to go into any detail.
I use Acrylic based paints and inks (many brands), Future, Testers dull coat, and Testers primers in my airbrush.  The Badger cleaning solution does not seem up to the task to clean up all these materials.  What do you guys use to clean your airbrushes?
Thank you,
Warmuncher
You can find me on Photobucket under Warmuncher
Proud Member of Southern Maine Scale Modelers, IPMS
    June 2009
Posted by kermit on Saturday, August 6, 2011 11:22 AM
First of all, a warm and big welcome to the FSM community. I have no doubt you will have lots of fun discussing the hobby on here and pick up a tip or two while you're at itWinkYes
Before you go and buy an ultrasound machine (it does help though as i have been told) there are some tips that will help you keep your airbrush clean and in tip top shapeSmile
First of all you will need some items that will help you get into all the corners and hard to reach places. Get yourself some denture cleaning brushes and/ or pipe cleaners. they will get into places a normal q-tip will never. The q-tips will be neccessary though too. Lastly some sparingly applied vaseline or beeswax on the threads of the airbrush and needle will help too.
Furthermore, the kind of cleaning agent i use myself depends on the medium. In case of acrylic paints i always have a cup with water next to me with a good splash of 96% alcohol in it. You should be able to get a bottle at places like rite aid. In case of enamel paints i use mineral spirits to clean stuff up.
As a rule of thumb you will want to use the thinning agent you use while painting for cleaning as well. If it thins the paint it will clean it as wellWink
Starting out airbrushing i found this next page over at IPMS Stockholm very enlightening. Pictures ay more than a thousand words:
http://www.ipmsstockholm.org/magazine/2005/03/stuff_eng_tech_airbrush_cleaning_2.htm
Though it is a pretty boring subject and a chore that can be tedious to some it is vital to have a good, clean airbrush. Not having a clean brush will cause you a multitude of possible/ probable problems while painting and will decrease the life of your airbrush.
Hope this helps you along further!Smile
Richard
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
    December 2003
Posted by hkshooter on Saturday, August 6, 2011 11:34 AM
Good advice there from Kermit.
Something I've found works for me, generic lacquer thinner will clean any medium I use in my AB. For some reason I still use Windex for Future but for everything else it's lac thinner. Easy.
    August 2006
Posted by Brian D. on Monday, August 8, 2011 7:55 PM
My new favorite cleaner for my airbrush is Simple Green.  I mix with water then spray it through my airbrush.  Then when I take my airbrush apart I clean it again with Simple Green.
I would clean with lacquer thinner though to get rid of the dried paint in your airbrush as mentioned above. Don't know if Simple Green would take care of that.
Brian
    January 2006
Posted by dirkpitt77 on Monday, August 8, 2011 8:10 PM
I use Model Master Acryls almost exclusively, so for an airbrush cleaner I use Windex With Ammonia.  You can buy a nice big bottle of generic windex with ammonia for cheap, and it lasts forever.  On occasion mine will get a bit of buildup too, so in that case I'll drip a little lacquer thinner through it til it's clean again.
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    October 2010
Posted by Warmuncher on Monday, August 8, 2011 8:38 PM
Hey guys.  Thanks for all of the great advice.  I remembered that I had a container with Simple Green in it.  I use it to strip the paint off of pewter minis.  I decided to soak my airbrush in it for a few hours and low and behold the paint wiped off.  I then ran some through the airbrush for good measure.  It seems to have worked pretty well.  I did notice a lot of bubbles coming from the threads and will spread a little Vaciline on them.  Thanks for that tip.  If you have any other please post them. :)
    May 2011
Posted by AceHawkDriver on Monday, August 8, 2011 10:14 PM
dirkpitt77
dirkpitt77:  you may already know since you've been using windex all along, but be very careful with letting ammonia sit in your AB.  ammonia has the ability to etch brass, a large component of most airbrushes, and can ruin it if not careful.  I too use it for future, acrylics, etc but always run a cup full of clean water afterwards.
Peace through superior firepower.
Brian
    May 2003
Posted by kirk4010 on Monday, August 8, 2011 10:56 PM
A good brew for cleaning up after spraying Acrylics is 1/3 Simple Green + 1/3 Windex + 1/3 Distilled water.  It is what I use in both my Badgers.  I believe Badger recommends their cleaning solution to be used only with their paints.
The art of war is simple enough. Find out where your enemy is. Get at him as soon as you can. Strike him as hard as you can, and keep moving.-Ulysses S. Grant
    October 2010
Posted by Warmuncher on Tuesday, August 9, 2011 11:39 AM
I've tried thier cleaning solution and it doesn't clean anything that I'm currently using.  So, you may be correct that it is specific for thier own line of paints.  Thank you everyone for the wonderful information you've shared with me.
cml
    March 2007
Posted by cml on Monday, August 15, 2011 1:34 AM
AceHawkDriver
 dirkpitt77:
I use Windex too and didn't know this - thanks for the heads up.  I'll be sure to flush out thoroughly with water after the Windex.
Chris.
Chris
    October 2010
Posted by Warmuncher on Monday, August 15, 2011 9:55 AM
That is a good thing to know about Ammonia and Brass.  I had no idea.  I took a look at Simple Green last night and didn't see Ammonia on the label.  Any idea what is in this stuff and what effect it will have on Metal and brass parts?
    December 2003
Posted by danok2 on Monday, August 15, 2011 8:00 PM
About 15 years ago the MTA used Simple Green to clean the ceiling in Grand Central Terminal.  It removed 90 years of soot, smoke, grime, etc., and didn't harm the mural of the Zodiac on the ceiling.  I doubt it will harm your airbrush!  http://en.wikipedia.org/wiki/Grand_Central_Terminal#Ceiling
-Dan
"Ahh, the Luftwaffe. The Washington Generals of the History Channel."-Homer Simpson
    May 2005
Posted by Bgrigg on Monday, August 15, 2011 8:44 PM
Windex is a perfectly good cleaner for airbrushes, What you shouldn't do is leave it to soak overnight in the stuff. Clean it up, rinse well with water, I use distilled, and you'll be fine.
So long folks!
    August 2011
Posted by GreenThumb on Tuesday, August 16, 2011 12:00 AM
kirk4010
I believe I posted that mix on here way back in '03 or '04. Works good huh? Cool
    February 2011
Posted by randypandy831 on Friday, August 19, 2011 10:34 PM
when i spray acrylics i clean with alcohol then wipe the cup down then spray some more alcohol. i let the needle sit in alcohol while i rip the AB apart and clean with again alcohol and use cleaning brushes. reassemble it then spray some more alcohol. my AB sat for month with no sticking.
i clean the same way when using enamels. i just used enamel thinner to clean it.
tamiya 1/48 P-47D $25 + shipping
tamiya 1/48 mosquito $20+ shipping
hobby boss 1/48 F-105G. wings and fuselage cut from sprue. $40+ shipping.
    June 2009
Posted by kermit on Friday, August 19, 2011 10:48 PM
Some of the answers on this thread makes me wonder.... Do you guys just spray alcohol through your AB to clean it without taking it apart and properly clean it everytime?
I mean, isn't that the highway to hardened paint and all related nasty stuff in the long run?
Could be me overzealous but each and everytime i use my AB i take it apart and clean thoroughly. Sometimes after a quickie sprayjob i spend more time cleaning than spraying...
Richard
    August 2011
Posted by GreenThumb on Friday, August 19, 2011 11:29 PM
kermit
Yes that is what I do. I take it apart about every 4th or 5th time of use. Other times I will just spray out well and then remove the needle and tip and put them in the ultrasonic cleaner and then lube the needle with Badger Needle Juice and reinstall it.
If you do it right and back flush there is no problem.
If you want to do that then go for it but I choose not to for the same reason Ken Schlotfeldt doesn't recommend disassembling it each time......bigger chance of damaging the needle, tip, etc.
    August 2011
Posted by GreenThumb on Friday, August 19, 2011 11:35 PM
AceHawkDriver
Some say that but I would take it with a grain of salt. Airbrushes have been used for many years with ammonia cleaners and it never hindered the airbrush whatsoever. Exercise caution of course but don't worry about it as Windex is not that harsh. Besides the airbrush is chrome hardened which protects it.
    February 2011
Posted by randypandy831 on Saturday, August 20, 2011 10:22 AM
i rip it apart and do a deep clean after each use. no matter if its acrylic or enamel. take care of your tools and they will take care of you.
    April 2004
Posted by keilau on Saturday, August 20, 2011 12:46 PM
kermit
Richard
Yes, I am afraid that you may be overzealous. But it depends on your airbrush. You want the airbrush in clean condition and works well all the time, but you do not want to take all the fun out of modeling. Yes, it will make you using the airbrush a lot less if you HAVE to take it apart everytime.
Mike already gave you the answer in the previous post. I just want to echo what Mike said. I do not find taking the whole airbrush apart each time necessary. (Well, I used to have to do that with my Paasche H, but have not been since I switch to the Iwata HP-CS.) This should be true for most name brand, internal mix, double action, gravity feed airbrushes.
I spray clean and then backfluch my airbrush in between colors. At the end of the day before I put the airbrush away, I take out the needle to wipe it clean. I also clean the nozzle with an "airbrush cleaning brush kit" like this:
Here is an airbrush cleaning video that I like the best.
