DogTailRed2:
So when a review or model maker says "set 15psi" is that before or after you press the airbrush button, and what effect does the drop in pressure on the gauge when using the brush have?
I set 15psi. I press the airbrush button, pressure drops. So is this an actual drop in pressure or should I ignore?
Hope that makes sense!
The pressure gauge should measure the static pressure at the compressor outlet. If set up correctly, the reading should not change. With a good setup, the compressor pressure should not have changed according to the amount of air or thickness of the paint you use. Otherwise, the airbrush user loses control of the airbrush.
If the reading changes when you press the trigger, it is either the compressor is too low powered to maintain pressure, or the gauge not set up correctly to measure the static pressure. Yes, my first compressor, a Silentaire Scorpion-1 clone, did that. The motor does not have enough power. I set the pressure at 25 psi with a Paasche H. The reading drop to less than 10 psi when I airbrush. My Paasche DA400 will not do that. I set the pressure at 17 psi for my Iwata HP-CS, it stays at 17 psi when I press the trigger.
The bottom line is to get a good quality compressor. In today's market, it does not have to be expensive. There are some good choices among the name brand and some house brand. For the cheaper single cylinder, w/o tank compressor, it is not unusual for the pressure reading to drop 2-3 psi when pressing the trigger. It is ok as long as the reading is stable and repeatable.
If the pressure reading drops more than that or continue to drop when you hold down the trigger, the compressor is probably too low powered for your airbrush.
