That's not bright enough!
Posted by arnie on Wednesday, August 17, 2011 12:13 PM
I use an airbrush to apply Future to my aircraft models for decals and weathering.  My problem is I can never get it applied to a smooth finish. If I hold it in one place long enough to get the effect I want, it starts to puddle.  When I try building up multiple layers I usually  get an orange peel look.
My pressure is set at approx 15psi and I spray a medium-to-heavy volume, about 1"-1.5" wide. The middle portion of the spray pattern looks good but the outer edges are hazy.  So, when I move along to the next panel, the outer edge of the next spray pattern (hazy) lands on the previous panel making it hazy also.
What I usually end up with strips of gloss and strips of hazy.  Any suggestions?
"There is a fine line between 'hobby' and 'mental illness'."---- Dave Barry
"Giggity"      -------------------------------------------------------------       Glenn Quagmire
    April 2011
Posted by Italian Starfighter on Wednesday, August 17, 2011 4:56 PM
Hi Arnie,try to cut Future with Tamiya thinner X20 at about 50%.Then check very well the duse of your AB sould be partially clogged or broken.With diluite Future apply several layers.....Enrico.
P.S.Try also to decrease pression ...try on an old model......
http://img.photobucket.com/albums/v381/tigerman12/ThatsAmoreGBBadge.jpg
Posted by Bish on Wednesday, August 17, 2011 5:06 PM
It sounds like you are trying to spray one panel at a time, but i don't get why. I just spray Future staright. I just spray on a coat all over in one go, without stopping my movement then leave it to dry, and if needed, give it a second coat.
    October 2008
Posted by Don Wheeler on Wednesday, August 17, 2011 5:50 PM
I'm with you, Arnie.  I can't spray Future worth a darn either.  But, it goes on so nice and smooth with a soft flat brush, that I don't see any need to.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
Posted by Wingman_kz on Wednesday, August 17, 2011 8:54 PM
Sounds like you aren't overlapping your passes enough. When I thin Future I use water. Distilled water 'cause the water here is very hard. I've tried thinning with alcohol and such but it always makes it cloudy, water doesn't. Yeh, Future is already pretty thin but, for me at least, adding a little water makes it easier to control. There seems to be a fine line between just right and too much.
Tony
Posted by arnie on Monday, August 22, 2011 2:01 PM
Thanks all!  Looks like I've got some experimenting to do.  I'll try all suggestions.
Posted by Don Stauffer on Tuesday, August 23, 2011 8:42 AM
Multiple layers shouldn't cause orange peel. There may be something else creating the orange peel.
That being said, gloss painting is a more difficult task that for flats. I consider gloss painting an exercise in brinkmanship.  You get best gloss just an instant before paint runs.  How do you know paint is just about to run?  Experience and good lighting.  Sometimes you are best off actually seeing a reflection of a light in the surface you are painting.
Different paints look different just before they run, so you need to practice- get experience- with each type of paint you use.  So practice getting that really wet coat of future on a scrap painted with the paint you will be using.
