Acrylic Varnish
    March 2011
Acrylic Varnish
Posted by kiwimo on Tuesday, September 20, 2011 11:22 PM
Hello, new member here.
Apologies if this questions has been posted a million times before.
I am using Tamiya and Humbrol enamels. I don't have an airbrush so I just brush on Tamiya clear gloss (x-22) as the protective coating. I am in South Korea and and I cannot buy futures floor polish. I was using Winsor and Newton All Purpose matt for the final dull coat which works well but is now hard to find. What I can buy is Winsor and Newton Acrylic matt and gloss varnish. Will this be ok on enamels. I thought a rattle can might give a better finish than the brush so does anyone know a good brand other than futures.
Your thought s would be greatly appreciated.
Thank you
Hamish.
    April 2009
Posted by Cadet Chuck on Tuesday, September 20, 2011 11:29 PM
Testor's Model Master clear gloss lacquer, in a spray can, works very well, if you can get it there.  I like it better than Future.  Sorry, I am not familiar with the other brands you mentioned.
    March 2011
Posted by kiwimo on Tuesday, September 20, 2011 11:33 PM
Thanks for the reply. I can get all the major model brands just struggling with some sort of gloss/matt varnish. I will look for ther Testors product.
Thank you
    March 2011
Posted by kiwimo on Wednesday, September 21, 2011 12:15 AM
I managed to find Testor's Model Master clear gloss lacquer (which Cadet Chuck suggested). I can get it in a bottle but haven't found in a spray can yet, which is an option but I also found Humbrol Acrylic Matt and Gloss clear in a can. Has anyone used these and can they be sprayed on enamels?
Thanks.
    June 2010
Posted by DoogsATX on Wednesday, September 21, 2011 1:26 AM
Acrylics can be sprayed on enamels no problem. In fact, they're almost preferable in that case since they won't react with/degrade the enamel the way a lacquer might (I stress might...).
Just be sure to leave the enamel plenty of time to gas out before sealing it. I have zero experience with Humbrol or Tamiya enamels, but Model Master enamels are usually good to go in 1-2 days. White Ensign, the other enamel I've used, can take as long as a week. Basically when it stops smelling like paint, you're good.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    January 2003
Posted by TomZ2 on Wednesday, September 21, 2011 1:57 AM
Short compatibility matrix (thanks to Masataka Narita)
____________ Over coat
Under Coat___________
 Acrylic  Enamel
 Lacquer
                 Acrylic      OK   Maybe      NO
                 Enamel      OK      OK      NO
                 Lacquer      OK      OK      OK
The L E A (Lacquer Enamel Acrylic) Rule: Lacquers, enamels & acrylics can safety cover base lacquers. Enamels & acrylics can cover enamels (but not lacquers!). Base coat acrylics can only be covered by more acrylics.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    October 2007
Posted by Milairjunkie on Wednesday, September 21, 2011 3:07 AM
If you are struggling to get W&N products, you could try having a look for Liquitex - they make a range of acrylic varnishes which are pretty decent, although they don't come in spray form. Failing that, I would suggest that you try & have a look in an art supply shop, most now carry comprehensive ranges of acrylic products, often including spray varnish.
    March 2011
Posted by kiwimo on Thursday, September 22, 2011 2:40 AM
Thanks to all for your wisdom. I am now happily shopping!
