How do I paint tire letters?
    June 2009
Posted by Falcon10275 on Wednesday, October 19, 2011 11:22 AM
Does anyone know the best way to go about painting the good year eagle letters on this old kit's tires?  I am worried its going to look sloppy and might be better not to paint them at all.
http://postimage.org/image/mx0hnzr8/
    January 2009
Posted by Griffin on Wednesday, October 19, 2011 11:27 AM
You could try drybrushing them if they're raised. Or you could use a white pencil crayon.
I don't know, I'm new here.
Good Luck!
Posted by echolmberg on Friday, October 21, 2011 2:01 PM
Falcon,
I'm not a bit automotive modeler but I could swear that I once saw somewhere that you can get aftermarket decals specifically for tires.  You might want to explore that avenue.
Good luck, best wishes and welcome to the forum!
Eric
    January 2011
Posted by stymye on Saturday, October 22, 2011 1:53 AM
I do  a fair amount of car modeling .  I use a pencil  eraser.
give the eraser end a round shape  than dab it onto  a thin layer of paint.
the eraser will absorb just the right amount and get a little sticky
than gently start dabbing over the lettering , you can increase or decrease the amount of white by
dabbing the eraser  on a sheet of paper.
I use acrylic paint so if I make a mistake a wet brush will flood it out of the crevices
 I finish with a seal of dullcote or satin clear
a lot of guys use the white gel pens , I haven't tried them yet
there are decals also , you have to spray gloss(or future) the tire first, apply the decal than  spray a flat or satin to blend them in
    October 2004
Posted by jschlechty on Monday, October 24, 2011 11:33 AM
I just finished a Spitfire that had raised "DUNLOP" lettering on the tires.  I used the drybrushing technique and it turned out fine.
