Tamiya Flat paints and tac marks
    September 2010
Posted by vaw1975 on Thursday, October 27, 2011 8:13 AM
Hi there. I am painting an RAF fighter with Tamiya XF paints (DEAD flat) and want to use the tac worm technique to mask for a soft camo pattern. I have seen build videos where they show how the oily marks caused by the tac is rubbed off, but those guys usually had a smoother finish (almost satin) which easily wipes clean. I cannot see how oily marks can be rubbed off a dead flat finish such as Tamiya's flat paints. Any tips or advice?
Vivian Watts
(I'm a guy, despite the name)
On my bench: Hasegawa Hurricane Mk I
    October 2007
Posted by Milairjunkie on Thursday, October 27, 2011 10:09 AM
I use Blu-Tack for masking, which is similar to most white/poster tack;
When the stuff is brand new it is a little bit oilier than idea, so I usually leave new stuff out of it's packet for a few days to let it dry out slightly - I have also left it sitting on a warm (not hot) radiator for a few hours to help dry it out slightly.
When I do use it, I tend to get it on & back of the model pretty quickly to help prevent any stains, if I do get any I just carefully roll a softened bit of it around over the stain to "soak" it up & then leave it sitting for a while. On a couple of occasions (both on light greys) it left a slight stain, but after clear coating with Future the stain couldn't be seen.
The stuff has a load of other uses for modelling, it's great for supporting things like landing gear doors at the correct angle while the glue is drying & I've got a big flattened out bit that I use for mounting small parts on for airbrushing.
    February 2011
Posted by randypandy831 on Sunday, October 30, 2011 4:01 PM
i only use blue tak.
tamiya 1/48 P-47D $25 + shipping
tamiya 1/48 mosquito $20+ shipping
hobby boss 1/48 F-105G. wings and fuselage cut from sprue. $40+ shipping.
    September 2010
Posted by vaw1975 on Tuesday, November 1, 2011 11:20 AM
Thanks guys! I have been using Elmer's tack which is orange and seems much drier than the white kind from Staples and the Silly Putty. I have not been able to find Blue Tac anywhere and I live in Northern VA!!
    October 2007
Posted by Milairjunkie on Tuesday, November 1, 2011 12:13 PM
I'm not sure if you will find Blu-Tack in the US, it seems to be more predominant in the UK - I think Elmer's Tack is more or less the same.
    February 2011
Posted by randypandy831 on Thursday, November 3, 2011 9:52 PM
true. i had to get it online.
