Got my new compressor
Posted by Don Stauffer on Thursday, November 10, 2011 8:43 AM
I decided on the Iwata Silver Jet compressor and it came yesterday.  Tried it out yesterday afternoon.  Tried it with my Badger 200- works fine.  Haven't tried it with my 150 which is disassembled for a thorough cleaning.
The compressor is very quiet, though there is a bit of drumming from the top of the stand I put it on. I think if I set it on a rubber isolation pad it will be even quieter. I am sure I could carry on a normal conversation with it running.
It came at a good time.  The cheap pancake 1 gallon general purpose compressor I have been using is starting to fail- the regulator will not regulate properly below about twenty pounds, so that compressor will go to the garage for general work, and glad the new compressor came in time to replace it.
    April 2004
Posted by keilau on Saturday, November 12, 2011 8:47 AM
EBergerud
I was wrong about the Silver Jet I guess: they claim 30PSI maximum with 10-18 "cruising range." Probably means you'd get heat trouble with a long blast at high psi which would cause a shut down. Chicago Airbrush claims 40 DB for the Iwata Silver Jet - that's very quiet indeed. Also comes with a moisture gadget that sits between the hose and airbrush: a nice touch. My Chinese clone is a tad more powerful and has no trouble staying over 25 which I use mostly for cleaning the brush. My comfort zone is about 18 psi for painting. So this has been worth the time for me: if my Chinese clone compressor dies, the Silver Jet sounds very good for my use in my condo.
Eric
Don, is Eirc's description of the Iwata Silver Jet accurate? What is Badger's recommendation for the 150 use? Very interested in knowing how well the 150 works at 18 psi.
Also, what do you mean by "drumming from the stand". Good that you like your new toy.
Posted by Don Stauffer on Saturday, November 12, 2011 9:08 AM
keilau
 EBergerud:
Eric
Since I don't use more than 20 psi normally anyhow, I have not tried to crank it up above 20 (on that little gauge you can't tell difference between 18 and 20 anyhow.  But it maintains near 20 fine. I have been spraying gloss lately, so using 15.
By drumming I mean the top of the stand accentuates the low frequency hum, and kind of gets louder and softer in a pattern, like a beat note.  I guess the resonance of the top is near the frequency of vibration of the compressor, but not quite.  We have been putting those new rubber patio blocks down in the back yard, and had some trimmings. I put two halves together on top of stand, and put the compressor on top of it.  That solved the drumming. I can listen to my radio now when I airbrush, without using headphones :-)
BTW, I would recommend those blocks for vibration isolators for any power tool.  They are much cheaper than the isolation pads sold in hardware stores for that purpose.  The blocks/tiles are a foot square.
Posted by Bish on Saturday, November 12, 2011 9:15 AM
keilau I have a revell masterclass compressor that i use with my Badger 150. I have used it with psi rangeing from 10 to 30+ psi and not had any issues with it.
    April 2004
Posted by keilau on Sunday, November 13, 2011 12:27 AM
Bish
The Revell Master Class Kompressor is similar to the Iwata Power Jet. It goes up to 80 psi and 1.13 CFM. With the auto-on-off, it will run very cool at 30 psi. The Silver Jet runs continuously and can go only 18 psi and 0.33 CFM. It is not a fair comparison.
I understand that the Badger manual recommend 20-50 psi and 30 normal for the 150. Heat is the worst enemy to the oilless compressor. Compressor runs very hot if you push it above the recommended pressure range.
Posted by Don Stauffer on Sunday, November 13, 2011 11:13 AM
keilau
 Bish:
While Badger may recommend the higher pressures, I run my 150 at about the same pressure I run the 200- 20 for flats, 15 for gloss.  And while the Silver Jet runs all the  time, it is so quiet that that is okay.  I find myself startled at times when a louder compressor which starts and stops does its startup. I have sprayed glitches due to the startle reaction.
