1st airbrush and compressor
    December 2011
Posted by KarlCr on Monday, December 12, 2011 2:24 PM
I am looking to get some advice on possibly purchasing an airbrush and compressor for the first time for painting model aircraft.
I would be a first time user but that said I'd like to get something that is of sufficient quality to be satisfactory as I become more expert.
I've looked at advertisements in modelling magazines for badger, iwata and aztek airbrushes but need some guidance on what is most appropriate for me. I think I would prefer an internal mix airbrush and it would be great to get a kit that has most of the accessories I will need already with it. A lot of model reviewers in magazines tend to use gravity fed airbrushes but I'm not sure what is best? I like to work with 1:48 scale model aircraft so I need a good mix of detail precision work as well I guess?
Any guidance/advice you could offer would be appreciated?
Karl
    October 2007
Posted by Milairjunkie on Monday, December 12, 2011 2:47 PM
A double action, gravity fed brush from a reputable manufacturer would be your best bet, other than making sure that you go for a mid size needle/nozzle combination (0.2>0.4 dependent on the particular brand) you can't really go wrong. On the compressor side, a piston compressor with a filter / regulator and output in excess of 0.5CFM will work just fine - if you can afford one with an air tank, all the better (reduces compressor wear, helps reduce moisture problems & makes the compressor less obtrusive in noise terms).
With regards to kits, you will often find that you will pay through the nose for things that you may never use, generally speaking with the exception of paint all you need is an airbrush, compressor & hose. An airbrush stand is an often overlooked item - especially when using a gravity fed brush.
    December 2011
Posted by KarlCr on Tuesday, December 13, 2011 2:55 PM
Thanks so much for the advice, greatly appreciated! - I am thinking about buying the Iwata Eclipse CS airbrush (I think it comes with a 0.35mm needle/nozzle and a 0.5mm needle/nozzle) and an Iwata Studio Series Smart Jet Plus Handle Tank Compressor which I think has everything you suggest - what do you think? I presume this is fine with thinned enamal paints (stupid question?)?
Grateful for your thoughts on how troublesome this might be for cleaning/changing over to another colour, etc?
Karl
    August 2011
Posted by GreenThumb on Tuesday, December 13, 2011 3:05 PM
Better yet get a Badger Krome for about the same price. Wink
    October 2007
Posted by Milairjunkie on Tuesday, December 13, 2011 3:23 PM
KarlCr
The Eclipse CS (or the Krome as Mike suggests) are both fine airbrushes for the job, the Iwata compressor is also fine for the job, but they are somewhat expensive for what you get. Sparmax manufacture Iwata's compressors & comparative Sparmax products (with a regular tank as opposed to a handle tank) can often be found for somewhat less than the Iwata versions. I'm assuming that you're from the US, in which case you may have to have a good scour about to find a Sparmax, but they are available.
Yes, fine with thinned enamel paints.
    April 2004
Posted by keilau on Wednesday, December 14, 2011 1:57 AM
Milairjunkie
In UK, the Revell Master Klass Kompressor is a good buy. Same as the Iwata Power Jet, but at much lower price. At Wonderland Models.
In US, the Sparmax TC-5000 is the equivalent. At Madison Art Shop.
    December 2011
Posted by KarlCr on Friday, December 16, 2011 5:42 PM
Thanks again for your reply.
I checked out the master class compressor and it certainly is better value but the problem is that Wonderland don't do the Iwata Eclipse CS airbrush, or any Iwata airbrushes, and, as you mentioned, its probably best to get both from the same supplier.
Could you recommend any of the airbrushes that Wonderland do that might be of similar quality? They don't seem to do the Badger Krome that Mike suggested either.
Grateful for any more guidance on what to do/what other suppliers might be good to look into?
Karl
    April 2004
Posted by keilau on Friday, December 16, 2011 8:54 PM
KarlCr
Karl
You don't need to buy both from the same vendor. If you are in UK, check out Milairjunkie wet site. You get a price advantage buying the Harder & Steenbeck brand because it is made in EU. The H&S Evolution Silverline is a very good value. Shop around. I am in US and don't really know where the best deals are in UK.
