Definitely, you must use Testor's metallizer sealer over it when it is thoroughly cured. Then let the metallizer sealer cure completely for a few days, and you should be able to mask over it ok.
Also note, the metallizer paints, especially the buffing kind, are meant to be sprayed on clean, unprimed plastic surfaces for best results.
I know this to be true, from experience. Good luck!
