Air Pressure for Acrylics ?
    November 2011
Posted by Fokker104 on Saturday, December 17, 2011 11:10 PM
Making the switch from enamel to acrylics, mostly Vallejo paints.
What is the recommended air pressure for the compressor to airbrush with my Badger?
Looking at a Badger Air Star V T909 compressor with the following data:
Normal 0 21 false false false EN-US X-NONE X-NONE
"1/8-Inch horsepower, on-off switch, maximum pressure 40-PSI, operating pressure of 25 to 30-PSI"
Will this work or any other recommended compressors?
Thanks in advance.
    April 2004
Posted by Jon_a_its on Sunday, December 18, 2011 10:47 AM
This brand really prefers a primer, eg I really like their Poly-eurethane primer available in lots of military colours, info here:  http://www.acrylicosvallejo.com/gb/primers-gb.html
read up about ModeAIR & ModelCOLOR on their website.
These are sprayed un-thinned & at a higher pressure than normal & go down really well.
With Vallejo, start low air pressure & then turn it up a bit.
I find that with Vallejo AIR, i thin a little, & Model COLOR, thin a lot.
Then it's a combination of  air pressure, viscosity (of paint), brand of thinner, distance from target, if target has been primed, humidity, heat, brand of air-brush, nozzle size, (0.5mm works better for me with acrylics) & what combination worked yesterday MIGHT not work today!
Ther above might just be me, Huh? & your milage may vary... Surprise
There a few (!) tutorials on you tube, search & learn, don't expect to do show winning stuff first time out.... but most importantly, experiment & learn... & have fun!
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
Posted by Don Stauffer on Sunday, December 18, 2011 1:34 PM
I'm not a big user of acrylics, so keep this in mind when I talk about the subject.
However, I think many modelers use their airbrush at too high a pressure.  They want the airbrush to be more of a spray gun than a brush.  I get my best finishes at lower pressure, small distance, which means very small coverage area.  That is, the airbrush is indeed more like a brush, but one that does not leave brushmarks.  I typically spray enamels at about 15 psi, sometimes up to 20 for flats.  I generally use the same pressure for acrylics, because I thin them so I can use those pressures, which I am more experienced with.
    February 2011
Posted by randypandy831 on Sunday, December 18, 2011 2:28 PM
i spray 12-15 psi. 20 pounds max. same goes for enamels or acrylics. the closer you spray the lower the pressure should be. all paints should be thinned to the consistency of milk. other like it more thinned. depends on the person.
tamiya 1/48 P-47D $25 + shipping
tamiya 1/48 mosquito $20+ shipping
hobby boss 1/48 F-105G. wings and fuselage cut from sprue. $40+ shipping.
    April 2004
Posted by keilau on Monday, December 19, 2011 11:40 PM
I do not use Vallejo. I use mostly Tamiya or Model Master Acrylic, thinned. A 17 psi pressure work for me most of the time. I may adjust it up or down a little depending on the paint. For spraying larger areas such as applying primer, higher pressure (25-30 psi) can be used.
I must qualify the pressure value because not all the compressor regulator measures it accurately. I set the pressure at 17 psi before I spray and the reading does not change more than 0.5 psi when I push down on the trigger of the airbrush. I spray in very fine misty coatings by making multiple passes. It is important to get high enough pressure to get good atomization, but not too high to get runny paint.
If the pressure reading changes a lot when you start pushing and pulling on the trigger, it could be one of two conidtiions. If your compressor is very low powered, you may not get sufficient pressure for good atomization. If you get a powerful compressor and the reading drops, you may be spraying at a higher pressure than it actually reads.
The bottom line is experimenting until you get a smooth and even coat everytime. With proper pressure, your airbrush should be very responsive to your trigger action.
If you have a pressure setting recommendation, please, state what compressor you use. At least, mention the pressure reading to be the one before or after you push the airbrush trigger and the difference between them.
    December 2004
Posted by panzerpilot on Tuesday, December 20, 2011 12:00 AM
I've been using an Air Star V for 7 years now, with no problems at all. For most acrylics, 15-18 works just great. I use mostly Tamiya and Polly Scale. I used Vallejo for the first time on my last build. It likes a slightly lower psi, thinned with Future. Try 12 psi.
-Tom
    April 2004
Posted by keilau on Tuesday, December 20, 2011 7:18 AM
panzerpilot
Badger recently renamed the Thayer and Chandler Air Star V T909 compressor as "Badger Aspire Elite TC909" and lowered the price. The horsepower went up from 1/8 to 1/6 and maximum pressure from 40 psi to 57 psi. The case style also changed. Did they change supplier? Anyone knows the story behind it?
