Hi everybody,
I own an Aztek airbrush and am pretty happy with it.
Only, often while using the tan (30 mm) and grey (40mm) sprayheads, the painting goes well the first minutes and then competely stops. I use Vallejo acrylics which I spray at about 15 to 30 psi. The paint is sufficiently thinned down by using water and the sprayheads are thoroughly cleaned after use. What am I doing wrong?
Secondly, sometimes when cleaning the airbrush with water, the Aztek blows paint back in the jar instead of the other way around. Can someone please tell me what seems to be the problem here?
Thanks in advance for helping me out. :-)
