Hiya
I have a Atlantis PT310 compressor. I seem to be getting a small leakage of Air in and around the switch area on the main case. First question, Should a compressors casing be completely air tight?
I have tried to track done someone who services the Atlantis compressor here in the UK, do get some advice on whether the compressor needs repaired or not. I have had no luck so far. Can anyone out there help.
