Tamiya/Gunze and ability to "re-activate" a paint?
    February 2010
Posted by EBergerud on Sunday, January 15, 2012 2:30 AM
On another thread we're quibbling over thinners. Just stumbled on this bit on howtoairbrush.com. In an introductory article on "basics" the author is comparing Gunze/Tamiya (which he does not include with acrylics) with enamels: I'd never heard about the reactivation stuff:
"Tamiya and Gunze Sanyo (Also marketed as Mr. Color) Both behave pretty much the same. I thin them both with Gunze's Mr. Thinner. There are a couple issues with these paints. They aren't as durable as the "oil based" stuff. They are a little healthier than the "oil based", but they are not "Non Toxic". A couple advantages. They have an ability to, what I call, "Re-Activate"....if I get a fingerprint or a little dry spray, I have found that I can spray pure Mr. Thinner over the area and get it to flow again and smooth out. This can be done even after it has dried for weeks. Also, if you really screw up, Windex takes the stuff right off. Very handy for beginners."
Anyone validate this? That might be a useful tip if someone didn't watch a thumb or left something a little uneven. (I would never do either of these things.) Be a lot easier than touching up with paint.  If true it does give credence to the notion that Tamiya and Gunze paints are closer to lacquers than acrylics - if that matters. As I understand it, when an acrylic ages and starts to get lumpy, it's going to die pretty soon and there's nothing to be done. An older lacquer, on the other hand, can be revived nicely by adding some thinner.
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
    September 2010
Posted by potchip on Sunday, January 15, 2012 4:32 AM
Gunze Mr.Color range IS a lacquer based paint. I've heard Mr.Color range can re-activate as you described, the thing even if dried in a bottle can be made good again with their thinner. Using lacquer thinner as a carrier for acrylic based paint is nothing new and basically uses it's quick evaporation quality.
Tamiya's acrylic definitely does not become solvable once dried, enamel probably not so much but then again, I don't believe enamels (of the present day formula and manufacture) ever dry :P
As for paint adhesion/toughness, general consensus is Lacquer > enamel (though personally I believe enamels, especially Tamiya is very fragile, maybe after 2 years of drying) > acrylic. Drying time Lacquer < acrylic < enamel. Toxicity Lacquer > enamel > acrylic.
