Something else you might try is this: Paint your project in a contrasting color and let dry. Then coat the areas you want the final color to peel with a thin layer of rubber cement and let that dry. Then paint your final color and let it dry (24 to 48 hrs). When final layer of paint is completly dry, press masking tape over the areas of rubber cement and then pull up. Takes a little practice to get it right though.
