Spraying Tri-clour camoufloge
Posted by Anonymous on Wednesday, February 4, 2004 8:00 AM
In the past, I had a few dissapointing results while spraying tri-color camoufloge, which some times resulted in unpleasant apearences, is there an way I can spray tri-color camoufloge without having Big Smile [:D]Clown [:o)]Shy [8)]heavy oversprays of the last color?
Posted by Anonymous on Wednesday, February 4, 2004 10:16 AM
I just bring the air pressure down to between 10-15 psi (or even less) and spray very close and watch the direction of spray. In some cases you may have to mask but I avoid it as much as I can when doing soft-edge schemes.
Posted by Anonymous on Wednesday, February 4, 2004 11:05 AM
Are you saying you essencially draw the scheme on and then use the airbrush to outline these shapes.
I'm going to be doing my first camo soon and it is probably going to be the Overlapping method"
Posted by Anonymous on Wednesday, February 4, 2004 12:36 PM
I outline with the airbrush close then pull back to fill in. If this causes trouble with overspray then you might have to mask or just fill in keeping the airbrush close. Some people draw it on first, but I haven't tried that yet. I just do freehand.
    May 2003
Posted by qmiester on Thursday, February 5, 2004 10:49 AM
Carnage.
I do my schemes the same way plum1030 describes - just remember to keep the airbrush pointed back into the color you are applying. It will take some practice though.
If that idea bothers you, check the back issues of FSM. I seem to remember a couple of articles describing methods of getting "soft" edges using masking. I've never tried them but they might be what you want.
By the way I use a 50/50 mixture of thinner to paint (enamel)
Quincy
Posted by Anonymous on Thursday, February 5, 2004 2:39 PM
QUOTE: Originally posted by qmiester
Carnage.
re-Sign - Ditto [#ditto]
Posted by Anonymous on Thursday, February 19, 2004 5:20 PM
yep best way is to keep the paint uber thin, then u make sure that u are pointed in the direction of what you are filling in, the paint will take a while to fill in but it is better and it will go on thinner, preserving the nice panel lines for washing later.
    January 2003
Posted by plasticmod992 on Thursday, February 19, 2004 5:44 PM
Carnage,
What airbrush are you using and tell us about your technique, just curious. Sometimes the design of the airbrush can shed some light on how it achieves fine lines for muti-color camo outlining with little or no overspray; for example my single action, external mix, Paasche-H requires thin(1:1mix) paint, high pressure, low paint volume and the #1 tip to achieve excellent soft fines lines(1/16in). Wheres as my double action, internal-mix, Iwata HP-CS can take a thicker reletively thin (2:1 mix) paint, low pressure(10 psi), and a slight pull-back on the trigger to get awesome, superbely atomized fine lines(1/32in) for out-lining. Generally you will get less over-spray with thinner paint and lower air pressures; however as in the case of airbrushes such as the Paasche-H set up can differ due to it's design.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by Anonymous on Saturday, February 21, 2004 10:25 PM
How do you regulate the psi on the compressor. I hadnt thought about reducing pressure when doing camo.
    February 2004
Posted by tiger88mm on Sunday, February 22, 2004 12:49 AM
I use between 5 and 10 psi,and a very thinned almost a wash when spraying the 3 tone paint scheme also i free hand my paint scheme as if it was done in the feild mainly WW11 models-------experiment ---it's your best teacher----good luck
Bryan
