Protecting you needle: IQ of 70 required
    February 2010
Posted by EBergerud on Tuesday, February 14, 2012 4:04 AM
Perhaps things like this only happen to dopes like moi, but just in case I'll pass this along. I've got a HS Evolution - a sweet brush with expensive parts. It has a .20 needle that injures easily. I'd guess that most damage is done when taking out the needle and reinserting after cleaning - something I do often. Someone on YouTube showed that at least with a Harder Steenbeck, if you remove the nozzle (which is a snap with the HS) you can push the needle from the rear and pull it out from the front. Reverse the procedure for reinsertion. The tip is untouched by human hands. Have no idea why I didn't figure that one out a year ago.
A model boat is much cheaper than a real one and won't sink with you in it.
    October 2007
Posted by Milairjunkie on Tuesday, February 14, 2012 4:43 AM
This is almost a must for the 0.15 & 0.2mm needles as it's very easy to catch the needle tip on the chuck nut "guide" - it's certainly instant death for the 0.15mm needle.
Doing this can apparently accelerate the wear on the needle seal slightly, but the seals are readily available, cheap & easy to replace.
    August 2005
Posted by Phil_H on Tuesday, February 14, 2012 7:18 AM
Milairjunkie
That's open to opinion I think - consider that if you draw a needle out through the back of the brush, any dried paint, particularly if you use flats, will act as an abrasive on the bore of the needle seal and perhaps accellerate wear.
Half-full or half-empty, it depends on who you ask.... Big Smile
    October 2007
Posted by Milairjunkie on Tuesday, February 14, 2012 7:41 AM
Phil_H
 Milairjunkie:
Personally I don't buy it & have been removing / replacing my needles from the front since the day I got my Infinity (Identical seal arrangement as the Evo.). The needle identification notches are supposed to be the culprit & doing everything from the rear prevents these passing through the seal - but these are quite smooth & if they do cause an issue I really don't think that it's significant enough to be concerned about.
    February 2010
Posted by EBergerud on Tuesday, February 14, 2012 4:10 PM
How about taking it out from the rear and reinserting from the front? Then at least a clean needle would go in. And unless I've got a mutant or am losing my eyesight, the needle in the Evo has no marks on it to designate size. The Paasche does, but there's nothing on the Evo.
Eric
    February 2010
Posted by EBergerud on Wednesday, February 15, 2012 5:14 PM
Phil Flory the very sharp guy who runs Flory Models has different advice. He says remove the needle from the front and insert it from the rear. The logic is that it's a bad idea to drag a needle over the deepest innards of the brush while it could be carrying gunk. I hesitate to disagree with him because his advice is almost always right. But I'd guess that this would be a factor when pulling out a dirty needle from the rear (which is why Flory says pull it out from the front) but not much of a factor if you're inserting a clean one from the front. (Most videos on YouTube show insertion and reinsertion from the rear.) But I do know that it's very easy to nick a fine HS needle and that even slight damage to the needle will degrade the nozzle which in turn degrades the airbrush. But this can happen so slowly you hardly notice - until you buy new ones and remember how the HS is supposed to work. And that's expensive.
Anyway, I'm forwarding this question to Chicago Airbrush. Harder and Steenbeck is getting popular in the US, but for a long time they were one of the few places to carry the whole line. (The HS manual is very helpful: it says "carefully remove needle.")
Flory does urge his flock to drain their compressors. I've never done that even though there's a sign on my Senco advising users to drain it every day. Sure enough, out comes a nice little puddle of rusty water. That would be great stuff to get in your nozzle - bet it's good for the tank too.
Eric
Posted by Bish on Wednesday, February 15, 2012 5:18 PM
I have a Badger 150 and thats how i insert and remove my needles. But i don't put the needle or head on after cleaning. I put the needle back in its case. I have both the fine and medium tips and needles, and though i mostly use the medium, i don't see the point of putting a needle in when i might need to remove it the next time i use my brush.
    April 2009
Posted by Cadet Chuck on Wednesday, February 15, 2012 6:07 PM
I've always pulled it out from the back, and re-ineserted it from the back after wiping it clean, with several different airbrushes, and never had any problems.
    February 2010
Posted by EBergerud on Wednesday, February 15, 2012 8:02 PM
Just got an answer, sort of, from Chicago Airbrush. The tech there says he takes the thing out and puts it in from the rear out of habit. He also things doing from the front is a good idea with the Evo because its needle is so delicate.
This could be a matter of having a fine hand and good concentration. If you watch it, you can insert an Evo needle in with no harm. I fall asleep at the switch pretty easy, especially if I'm thinking about the actual painting or the fate of the universe. So I know I nick the thing sometimes on reinsertion. Even small nicks will degrade the needle and the nozzle. I can testify to that. (Badgers are known for ruggedness: a major review on the Krome warned of doing any damage to their .15 needle - maybe you can't make a rugged .15 or .2 needle.) For kicks I looked at all my brushes. The Paasche needles are thicker and look pretty good, although the nozzle for the Talon is starting to split. I think the VLS would spray if I ran over it with a car.
Eric
    August 2011
Posted by GreenThumb on Friday, February 17, 2012 6:34 PM
First of all you don't need to remove the needle every time you are done painting.
Secondly, it doesn't matter which direction you pull the needle out as the needle bearing keeps paint from getting into the airbrush body. Some airbrushes like the Badger Anthem 155, 360 and the Sotar 20/20 HAVE to come out through the back of the airbrush. If you are worried about damaging the tip of the needle then put on your magnifiers and insert the needle into the airbrush wearing those to see up close and watch the tip.
    February 2010
Posted by EBergerud on Friday, February 17, 2012 10:08 PM
Maybe it's because I favor pretty thin paint, but I've never pulled out a needle after a full session of spraying and found it clean. If a paint covers very well that means either it has very high pigment load, coarse pigment or both: I clean needle and nozzle after a color spray then. I know a lot of good modelers spray cleaner or water through and when it's clean call it a day and clean the brush once a week or so. I also realize it's possible that if you clean too much you could actually move ugly stuff into the nozzle. That said, at least my airbrush works best when nice and tidy.
Eric
    October 2007
Posted by Milairjunkie on Saturday, February 18, 2012 9:56 AM
EBergerud
Unless you have the 0.4 or 0.6mm needles, you're not going mutant or blind - the 0.15 & 0.2mm are not marked, the 0.4 has a single marking at the rear & the 0.6 has a double marking.
If you do have the 0.4 or 0.6, it's time for a mutant test & eye check!
