Need help with enamel
    October 2009
Posted by Kentucky Colonel on Friday, February 17, 2012 4:02 PM
I screwed up big time. I was painting a tank with Model Masters German Gray enamel from a spray can and I ruined it by getting way too much paint on it. After loking over the forums I'm using oven cleaner to remove the paint hoping to save it.
It's been years since I used enamel paints and I have never use it in an airbrush. I've been using Tamiya and other acryic paints so I'm used to that. I plan to buy some bottle enamel paint to repaint the tank.  I have a Badger 200  single action airbrush  and a Iwata Eclipse HP-CS double action. Which air brush should I use and how much pressure should I have my compresser set for? Also how much do I need to thin the enamel. in other words please school me.
Here's the deal. I plan on using the hairspray tecnique on this tank for a DAK finish with the Tamiya sand/tan color coming off. I was told that the enamel would be the best undercoat in German Gray. But I also plan to put a "barrier" of Testors Dullcote Lacquer between the Gernan Gray and the sand/tan color. I've thought about using Tamiya German Gray with the Dullcote "barrier" and then putting on another Tamiya sand/tan on top of it which I will rub off. Will that work without having to use enamel?
Either way I need some help here.
    June 2006
Posted by MaxPower on Friday, February 17, 2012 5:24 PM
Hi,
First of all you should know I don't even know what this hairspray method you speak of is. Must be an armor thing. I do know a few things about paint however.
Thin your enamel to simular consistency as you would your acylic. I don't even measure anymore I just thin untill it looks right to me. Spray at the usual pressure as well. I use a gravity and a syphon feed brush and I spray both at 18 PSI. Obviously you'll need to use a different thinner. I prefer the Model Master stuff. I use lacquer thinner to clean up.
Whenever I can I use Tamiya acrylic. I get great results, it's easy to clean up and I don't stink up the house. Because you are using a lacquer based barrier between coats I see no reason why you couldn't use the Tamiya. Somebody else wanna chime in on that?
Whatever paint you use I'd suggest don't over think it. Just apply what you do with acrylic to enamel. Use the airbrush you like better. I'd use the one that's easier to clean! Let us know how you get on. Smile
    August 2011
Posted by GreenThumb on Friday, February 17, 2012 6:40 PM
Kentucky Colonel
Why would you need a "barrier" between colors?
By the way, you can spray any type of paint over another if you do it properly and don't let anyone tell you otherwise. I can spray lacquer over acrylics and have done it on occasion. Wink
    October 2009
Posted by Kentucky Colonel on Friday, February 17, 2012 9:44 PM
GreenThumb
 Kentucky Colonel:
Hairspray is used to take off the top paint color. I'm doing a DAK tank and when they were shiped from Germany they were painted German Gray. Later they got a sand/tan paint job over them . With harispray between them I can remove some of the sand/tan paint making it look like it wore off. People dong it have told me I need a "barrier" between them so not to rub the base coat off.
    August 2011
Posted by GreenThumb on Friday, February 17, 2012 10:30 PM
Ah, I see. I am an aircraft modeler so I was not aware of that technique although I have heard of it.
