Mild solvent for oil paint washes?
    December 2011
Posted by Chrisk-k on Tuesday, February 28, 2012 2:29 PM
I'm new to washes and need some help.
What solvent is mild and less toxic? Mona Lisa? Or, odorless mineral spirits sold at home depot? Or, something else?
The reason why I'm asking is that with a mild solvent (1) I will less likely to damage the base coat, and (2) my health will suffer less :-)
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
Posted by Bish on Tuesday, February 28, 2012 2:40 PM
Provideing the coat you are applying the wash to isn't enamel, you won't damage it. I use normal White Spirits to thinn my oil paint have have only had a problem when i didn't cover the enamel base correctly.
    June 2010
Posted by DoogsATX on Tuesday, February 28, 2012 2:55 PM
Mona Lisa is very gentle...used it over enamel without damaging it. It also goes great with Bloody Mary mix...Toast
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
Posted by Bish on Tuesday, February 28, 2012 3:14 PM
Doogs, whats is this Mona Lisa. I haven't heard of it, not in this context.
    June 2010
Posted by DoogsATX on Tuesday, February 28, 2012 3:25 PM
Mona Lisa Odorless Thinner...pretty widely available here in the US - I've seen it at Hobby Lobby, Michaels, the local art supply store, etc. I believe it's actually a brand of odorless turpenoid, but it's very not-harsh and I've found it ideal when working with oils.
Posted by Bish on Tuesday, February 28, 2012 4:06 PM
Thanks, i will have to see if i can find it over here. Might help avoid any more accidents.
    December 2011
Posted by Chrisk-k on Tuesday, February 28, 2012 4:20 PM
I use Tamiya acrylic paints as base coats and will use a Vallejo acrylic glossy top coat as a base for decaling and pin washes.  I've read that an acrylic paint, once fully dried, will survive an oil paint thinner.  This is true, isn't it? About 20 years ago I was into oil painting (with turpentine) and I still remember the viscious, toxic odor of turp.
