Armor painting
    March 2012
Armor painting
Posted by 0leGISon on Friday, March 2, 2012 10:02 AM
I use Testors 1/4oz  flat enamels on my 1/35 scale tanks and vehicles. I've noticed straight out of the bottles they are not exactly flat but maybe more of a semi-gloss. I've also noticed that after I've used a portion of a bottle and come back to it a day or two later that the paint does get flat. Is my assumption correct that I may need to open the bottles and let them age a bit, or am i just doing something wrong?
Posted by rossjr on Friday, March 2, 2012 11:13 AM
I would be more inclined to think you are not mixing the paint enough when you first use it.  Shaking the bottle isn't always enough, I use a small screwdriver, also called a tweaker by some, to stirr the paint to make sure I get all the pigment that might have settled on the bottom, then shake it....
Posted by Don Stauffer on Saturday, March 3, 2012 10:52 AM
I agree that mixing very well is more important with flat paints.  Also, it is possible to get semi-matt/semi-gloss with either flat or gloss paints.  Gloss paints put on very dry/thin will give a semi, as will flats put on very heavy/thick.  Try thinner coats.
Also, if you are airbrushing flats, try a slightly higher pressure and a slightly greater brush-to-model distance.
Posted by Bish on Saturday, March 3, 2012 11:12 AM
I agree with the others, its all down to the mixing. I was recently given an electric paint stirrer, and that really does the job a lot better than shaking or stirring by hand.
I use Gloss enamel paints and sometimes find i get a semi gloss finish if it hasn't be stirred right.
    September 2011
Posted by OMCUSNR on Sunday, March 4, 2012 10:32 PM
And, if you ever start to use aluminum or a metalizer paint, stir till your arm falls off.
Reid
Grumman Iron Works Fan.
"Don't sweat the small stuff.  And.... it's ALL small stuff, until you hear INCOMING!!!!!!"
