Stupid spray booth question
    February 2012
Posted by Chopper Greg on Friday, March 9, 2012 10:06 PM
Ok, so my work space in an unused corner of the basement furnace room, and I have no access to a window in which to ventilate, is there any reason why I can't tap the ductwork to ventilate a small spray booth into the furnace exhaust?
I know, it sounds crazy at first, but in the summer the furnace is not in use and with electronic ignition, it doesn't have a pilot light, and since the ductwork has a small fan on it anyway ( in the attic ) to keep air flowing in the proper direction, it would be simple enough to install a manual switch to turn on the fan to prevent back flow into the furnace.   Add a 4" PVC line from the rear of the spray booth to a ball valve to prevent furnace exhaust from coming into the house in winter and from there up to the ductwork that serves as the exhaust ( for that matter, make use of a large electric irrigation valve, and when I turn on the fan in the attic the valve opens ).
Thoughts?
Posted by Don Stauffer on Saturday, March 10, 2012 10:03 AM
I wouldn't!  While the fact that you have a fan in the exhaust indicates a high efficiency furnace and the temperature is thus low enough it probably wouldn't ignite dried paint, I still wouldn't chance it.
I find that a filtered booth cuts down a lot on the fumes.  The filter collects the paint particles and they seem to outgas more slowly when stuck on the filter than they do in the air. Probably less surface area.   I see two purposes for a spray booth- cutting overspray in room, and reducing fumes/smell.  The filtered booth with no outside vent certainly fulfills the first purpose, and does help some with the second.
    February 2012
Posted by Chopper Greg on Saturday, March 10, 2012 2:29 PM
Don Stauffer
Please recall, I specifically specified that it would be used in the summer, when the furnace wouldn't even be in use, and that the furnace doesn't even have a pilot light.
    January 2009
Posted by fermis on Monday, March 12, 2012 7:29 AM
I just cut a 4" hole in the siding, between the floor joists(basement ceiling), plugged it up with a dryer hose/ flapper vent.
    February 2012
Posted by Chopper Greg on Monday, March 12, 2012 10:45 PM
I thought about something along those lines but the more I looked at the brick on that side of the house, the less I wanted anything to do with it.
    April 2009
Posted by Cadet Chuck on Monday, March 12, 2012 10:51 PM
No- I would not recommend messing around with your furnace in any way!  They are engineered to work as they have been designed, any modifications like this might be dangerous.
    February 2012
Posted by Chopper Greg on Tuesday, March 13, 2012 2:16 PM
Just for clarification, it would not be messing with the furnace, but tapping into the exhaust vent, in the same way that a NG hot water heater will also tap into the same exhaust vent.
