Escape068:
Can I use the hardware store lacquer thinner to thin the Testors Glosscote / Dullcote clears? The Testors thinner is expensive and if the hardware store lacquer thinner can be used it would be even more economical then the cans.
Also what is the ratio of lacquer thinner to clear? Currently I'm mixing 2 to 3 of thinner to clear
Thanks,
Scott
I've always used ordinary lacquer thinner with Testors Glosscote & Dullcote with good results. I use a 1:1 ratio for airbrushing.
I mix Glosscote & Dullcote for semi-gloss finishes. I usually start out at 1:1, then adjust depending on the look I want to achieve.
As far as decaling, I've had the best results with first applying Glosscote, decaling, applying a second layer of Glosscote over the decals and then my final coat of semi-gloss, flat or whatever final finish I want to achieve.
Mark
