primer still tacky....?
    December 2011
Posted by mike-mike on Tuesday, March 27, 2012 12:58 PM
 Hi all.
I primed my Italeri Tiger I three days ago with Testors flat grey spray primer.  I believe I held the can too close though because it's still sticky and looks glossy.
I don't suppose there is a way I can speed up the drying process...? If not,does anyone know how long it might take to dry...if it dries at all?
I'd greatly appreciate any help. Thanks.
Just passing the time while waiting for the mothership.
Posted by VanceCrozier on Tuesday, March 27, 2012 1:23 PM
Speed up the drying time... warm dry air would help a great deal.
If you were too close/applied too much, there should be puddles or runs visible - anything like that going on? If not I'm thinking that the primer is either faulty or not mixed well - was the can well shaken before you sprayed? Hmm
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    January 2009
Posted by paintsniffer on Tuesday, March 27, 2012 1:32 PM
Re-prime with a well shaken can..
Or, get some testors dullcoat lacquer and spray it on. That is flat, and will harden pretty fast so you can get on with your life. I use that method to deal with enamel gloss paints that never seem to fully harden.
Excuse me.. Is that an Uzi?
    December 2011
Posted by mike-mike on Tuesday, March 27, 2012 1:55 PM
No runs or puddles.....I made quick passes but too many of them I think.
 It's a brand new can so I don't think it a quality issue....it provided some very good coverage.
 I shook the can for at least two minutes maybe three.
    January 2006
Posted by RedCorvette on Wednesday, March 28, 2012 10:08 AM
Three days is a long time for Testors primer to dry.  Has your weather been very humid?  That and cool temperatures combined with a thick coat of paint would extend drying time.
I'd give it another day or so.  (My way to gauge whether paint is cured is by smelling it.)
I'd be reluctant to apply either more primer or any clear coats until I was sure the first coat had  completely cured.  That's just asking for a bigger mess, IMHO.  You might be better off stripping the original primer off and starting over.
Good luck,
Mark
FSM Charter Subscriber
Posted by VanceCrozier on Wednesday, March 28, 2012 11:35 AM
RedCorvette
I'd be reluctant to apply either more primer or any clear coats until I was sure the first coat had  completely cured.  ...
Ditto If it's not cured & a coat of something else is put down on top, you could get some "unexpected results".
    April 2005
Posted by carsanab on Wednesday, March 28, 2012 1:47 PM
my experience with Testors is that their primers and most rattle cans are garbage....goes on thick and takes forever to dry....Bang Head ....give it time...next time try Tamiya primer...
GRL
 Photobucket
    December 2011
Posted by mike-mike on Wednesday, March 28, 2012 5:58 PM
Well it's been another day or so and still no sign of it drying .  Not keen on stripping it...I've done that before and it sucked. Any super-glued parts come right off.
The weather's been nice lately...not too humid. So that's probably not it.
What I'll do is put it aside and start another kit.    If it isn't dry by the time I finish then I'm  gonna go ahead and base coat it. I'll be using Tamiya acrylics.
If it then reacts badly I guess I'll just have to strip it.Angry
    April 2010
Posted by El Taino on Wednesday, March 28, 2012 6:29 PM
I only use acrylics and never prime models but I've had a similar situation in the past. I painted a F-104G Jabo G33 with Testors Yellow from a rattle can. Days later still smelled and had a tacky feel. Give paintsniffer's suggestion a try. I did covered my model with a coat of Gloss Cote and problem solved.
    December 2011
Posted by mike-mike on Wednesday, March 28, 2012 8:55 PM
I think I will give it a try....I'd rather not have two kits going at once.  I've got a can of flat coat some where.
Thanks guys.
    April 2009
Posted by Cadet Chuck on Wednesday, March 28, 2012 11:14 PM
Perhaps this is not applicable to this situation-  but a few years ago, I had a nice resin figure of Vampirella.  I could not get any kind of paint to dry on it- I tried primer, acrylic, enamel, laquer, nothing worked.  I finally figured out the only reason could be that I cleaned the resin with alcohol thoroughly, before painting.  Apparently, that stuff soaked into the resin and caused the problem.  I sadly had to through the nice sculpture into the trash.  $100 down the drain.
Anyhow, I hope this will warn you guys about using alcohol to clean resin parts.
    April 2010
Posted by El Taino on Thursday, March 29, 2012 5:06 AM
Cadet Chuck
I'm curious Cadet Chuck, are you referring to resin of vinyl?
