Fanatstic response guys, thanks for all your feedback- given me some hope!
The part in question is definitely the nozzle which has a 0.35 exit tip
I can insert a metal brush bristle from the outside pushing through to clear the exit. The problem however is on the inside, there's obviously a build-up, problem is the nozzle is so small I cannot see inside from the entrance. I have left in laquer thinners soak when not in use
keilau/plastickjunkie: thanks for the airbrush guru website, very helpful cleaning guide. Yes old lumpy paint not a good idea, learnt that some time ago with my "H" but lesson not learnt, thought I would thin it out in the cup. Stocking good idea
Don Stauffer: what is a paint retarder? I use Tamiya accylics or occassionally Humbrol enamels because these are the easiest to get locally but
mitsdude/Virago/plastickjunkie: I've never heard of an ultasonic cleaner! But what a fantastic idea, just did some quick research, sounds like the answer - I will get a cheapie from HK & give it a go. Question - what solution is used, is water/detergent sufficient, can thiners be used?
Fudddy Duddy/keilau - I generally follow the cleaning routine described, do the handle bit aoccassionally,its just getting inside that nozzle is the issue, never know if it has be adequately cleaned until it blocks?
Wingman - willing to try whatever, problem is seeing inside
WiP
1/24 Hawker Hurricane Mk I
1/48 F-22 Raptor; F-22 Idolmaster, DH Vampire, Saab Gripen
1/72 C-130 Hercules; Vulcan
1/350 Bismarck
