Solve THIS airbrush problem (Badger 360)
    January 2006
Posted by dirkpitt77 on Friday, April 20, 2012 7:44 PM
    I set up to do some airbrushing today and discovered a pretty weird problem.  When I depress the airbrush trigger straight down for air, it does not shut off when I release the trigger.  Air then blows constantly out of the brush.  I disassembled the brush until I had only the air valve itself hooked to an air supply.  When I actuated it then, it worked fine.  I tested it again at various stages during reassembly, and it worked fine each time until the front end is completely assembled, i.e. head, needle tip cone, needle. Then the problem recurred.  I pressed the trigger again, released it, watched it continue to blow air, and then I slowly unthreaded the head from the front end of the brush.  As soon as I did that, airflow stopped and the trigger worked normally.  So for some reason when the head/needle tip assembly is tightened completely, it is preventing the air valve from closing when the trigger is released.
      Has anyone got any ideas or seen this before?  I'm stumped. Huh?
Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    October 2008
Posted by Don Wheeler on Friday, April 20, 2012 10:50 PM
It doesn't make a lot of sense, does it?  Does it do it with the needle removed?
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
Posted by Delbert on Saturday, April 21, 2012 11:38 AM
is there any paint build up inside the airbrush body between the head and the trigger ?
last time I had a problem with my 360's trigger (though it was leaking air back at that time)  when I used it, there was some paint build up inside there..
Delbert
    February 2015
Posted by Bick on Saturday, April 21, 2012 5:20 PM
Sounds to me that your needle may be bowed. Try it the other way 'round. Leave the needle out and tighten the nozzle,needle cap etc. If the air valve works then, it's likely something is rubbing the trigger to prevent it from rising and that is likely the needle. Is the hole through the trigger 'clean'? I'm not familiar with the '360' but if possible, also try loosening, very slightly, the air valve itself - an internal gasket could be binding on the air valve (ala a similar problem described by Phil Flory on one of his videos)
    January 2006
Posted by dirkpitt77 on Sunday, April 22, 2012 12:34 AM
  Bick,  you nailed it.  I took it apart again this morning, this time removing the needle first.  It worked fine without the needle in it.  I discovered the needle is bent enough so that if it is oriented a certain way in the brush, it presses on the trigger, creating a friction point that holds the valve open.  I gave the needle a little bit of a turn in the brush until the bend was oriented vertically.  It's working fine now but I'll have to pick up a new needle for it.   Thanks for the help, guys!
Chris
    February 2015
Posted by Bick on Sunday, April 22, 2012 4:52 PM
Glad you got the problem sorted out. A new needle is a sure solution but, with careful bending, you might be able to save the one you have - at least for a backup.
