spraying clear colors
    July 2008
Posted by jeffpez on Sunday, April 29, 2012 8:00 AM
I had to spray some clear parts with a transparent mix of blue/green and didn't like the results. I used Tamiya acrylics and thinned the mixture as I normally would and then sprayed the parts at about 18 or so PSI. The results weren't as smooth as I'd hoped. Some places were somewhat mottled and far from perfect. Does anyone have experience tinting clear parts and can you offer some hints?
    June 2010
Posted by DoogsATX on Sunday, April 29, 2012 8:20 AM
How big are the clear parts you need to paint?
I've never had a problem airbrushing clears (I airbrush a mix of Tamiya Clear Yellow/Orange to put the final touches on simulated varnished wood), but then I've never tried on a clear part. What thinner are you using?
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    October 2008
Posted by padakr on Sunday, April 29, 2012 8:50 AM
I've done a little.  Not with an airbrush, but by brush painting the backside of the clear part:
I used enamels, not thinned, because the "tint" on the colored lenses was supposed to me fairly opaque.
Depending on what you are trying to tint, (will it be seen from both sides of the part? how transparent the finished part needs to be?), this may work for you.
Paul
    July 2008
Posted by jeffpez on Sunday, April 29, 2012 10:00 AM
The parts are mostly about 1" square with one being twice that size (it's for Bronco's Buffalo 6X6). You'll be looking in from the outside although there's a door that will be open allowing you to also see the inside but only with great difficulty. The tint will be on the inside surface and isn't all that bad but it's not as perfect as I would have liked. I thinned with Tamiya thinner but not very much.
Posted by Don Stauffer on Sunday, April 29, 2012 11:03 AM
I have done small parts with a highlighter marker when the color needed was available in those markers.  It is too hard to make a uniform coating to do larger areas that way, however.
