washes on a flat finish
Posted by Anonymous on Sunday, February 8, 2004 4:00 AM
Hi there,
My name is Mark from the Netherlands and I have been modeling for about five years now and I find it's the greatest hobby in the world! Mostly I build aircraft and at this moment I am working on the Tamiya 1/32 F-15 Strike Eagle. Everything is going very well but I have some doubt about the technique I am going to use to apply a wash for the panel lines. So far I used Vallejo acrylic paints applied with my airbrush and a flat finish (also Vallejo). My question is the following: what technique and paints should I use regarding the flat finish and acrylic Vallejo paints I used? May be I could use thinned enamel paint, or does that leave greasy spots on the surface after wiping of the excess paint? Or should I use a sludge wash despite the flat finish? Does anyone has some advise for me since the F-15 looks really great and I do not want to spoil it!
I hope someone could help me out but I am sure someone will because this forum works very well in my opinion Smile [:)]
Thank's in advance!
Greetings from Mark
Posted by Swanny on Sunday, February 8, 2004 8:27 AM
Washing a flat surface is a very difficult thing to attempt because the wash will travel through and across it quickly. You should first seal the paint with a gloss coat like Future or other clear coating, let that cure for two days then apply your decals, another coat of clear then the washes. After the washes have dried put on a flat coating like Polly Scale clear flat or Testors Dull coat to bring the finish back to a flat look.
Doing it this way will protect your base coats, prevent your decals from silvering or peeling and result in a nice finish.
    December 2003
Posted by cbreeze on Sunday, February 8, 2004 11:46 AM
Kempen,
I have just gotten back into the hobby and have been reading and doing some experiments on different weathering techniques. I read an article about doing a pastel wash on flat paint without a protective coat. I tried it and it works. Can't remember where I read it it was either here on FSM or Aircraft resource center. Basically you just shave off a little pastel of your favorite color, mix wth water and a littlle soap. Try it on a test piece to see if you like it.
Posted by Anonymous on Monday, February 9, 2004 2:13 AM
Thank's for the quick replies so far! I think I will apply a new gloss coat first and then apply the wash, but I will try the pastel wash too on a test piece; I have never tried that one so I am very curious about the results!
Thank's everyone!
