Anybody Familar With This Spray Booth?
    July 2003
Posted by MonsterZero on Tuesday, June 5, 2012 12:28 PM
Pleas see the Amazon link below.
Do you know where I can get replacement filters for this booth type? How much do they cost? I had contacted the seller at Amazon but he's clueless; aparrently he knows nothing about this booth. He just sells them, he says.
This booth looks very similar to the Paasche booth, and I like the attractive price, but I'm worried about those filters.
Some booths use multistage filters that are so expensive to replace it's not worth it.
http://www.amazon.com/Airbrush-Spray-Booth-Paint-Extractory/dp/B004ZH7RSM/ref=sr_1_2?ie=UTF8&qid=1338917017&sr=8-2
    October 2007
Posted by Milairjunkie on Tuesday, June 5, 2012 3:48 PM
It looks like a Chinese unit manufactured by Ningbo Haosheng Pneumatics (& probably others), the HS-E420K;
http://www.haoshengnb.com/Product_Info.asp?ID=257
A quick search on HS-E420K should yield some results like;
http://runway13.com/store/index.php?main_page=product_info&cPath=1_13&products_id=103
    October 2009
Posted by Kentucky Colonel on Tuesday, June 5, 2012 4:13 PM
I've got one and it works great.
I got mine off Amzon and i remember them having filters for it though Amzon, they are more than cheap enough.
    January 2003
Posted by TomZ2 on Tuesday, June 5, 2012 5:35 PM
I use a ModelExpo’s Compact Spray Booth (HSE420 - actually the Compact Spray Booth, Exhaust Hose, & Filter Combo #HSE420PRO). What I like is the way this beast folds-up into a 16-1/2" × 6" × 9-1/2" box (the spray area is 16" wide × 13" high × 14" deep).
http://www.modelexpo-online.com/images/prod/p43238b.jpg
Even better deal for just $209.99, the “Super Saver Combo” version:
  1. HS08AC-SK - Mini-Compressor & Double Action Airbrush Set
  2. HSE420 - Compact Spray Booth
  3. HSE420H - Exhaust System
Available @ http://www.modelexpo-online.com/ — use offer code W383.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    April 2009
Posted by Cadet Chuck on Tuesday, June 5, 2012 6:22 PM
Rather than buy one of those expensive things,and knock a hole through the wall for the vent, I have opted to spray in my unfinished basement, with windows open, and wearing a NIOSH vapor respirator mask.  Works fine for me.  And I usually use water based acrylics, not too toxic.
I'm just sayin'....
    September 2007
Posted by kurtd123 on Tuesday, June 5, 2012 6:42 PM
I am lucky to have a 1/2 daylight unfinished basement.  I took a piece of thin (1/8" or maybe less) wood the width of the window and cut a strip just big enough to install a plastic dryer vent adapter (that normally is mounted in the wall).  I mounted the circular vent/flange to the wood and then attached the wood across the bottom of the window frame.  When I spray, I open the window just enough to clear the opening and exhaust the fumes outside.  the wood that is mounted over the window keeps the fumes from coming back in the basement.  It was way easier to do that my clumsy attempt to describe it...  I should probably just make a permanent opening but,  at the time - 10 years ago. I did not think we would be here this long!  You could probably do the same thing in a finished room by using thicker wood and making it so it fits exactly in the window so you can "close" the window on it to clamp it in the opening.  This would work in a finished room where you need something removable.
    March 2012
Posted by Chili on Wednesday, June 6, 2012 1:49 PM
I bought the identical Paasche version for ~$120.00, shipping included & it didn't have the hose extension-that's a good deal, even with the $14.00 shipping. Be aware, they are rather small so check the dimensions,and the fan is noisy.
