pressure settings
pressure settings
Posted by Anonymous on Monday, December 23, 2002 2:23 PM
I have a campbell and hausfeld compressor and a model master double action airbrush, what would be a good pressure setting for gp, and for fine lines?
Posted by jcarlberg on Monday, December 30, 2002 9:13 AM
Experimentation is the best way to find out, because different paints and different viscosities will come out different at the same settings. I find that most thinned model paints airbrush well at somewhere between 12 and 20 psi, with finer results with thinner paint at lower pressures.
Posted by Anonymous on Tuesday, December 31, 2002 10:08 AM
I use a CH five gallon air tank, old school I guess. I use water based acrylics and a single action brush. I find that a 60/40 mixture with a few drops of liquid detergent works wonders. I start out at 80 pounds and have great results, though I don't recommend this, since my pressure drops with usage. With a compressor, 20-30 pounds will give you the best results. Try acrylics, I think you will like it.
Posted by billc3207 on Friday, January 3, 2003 12:39 PM
I never use a pressure higher than 25 psi because of the excessive over-spray that it causes. All of that paint will settle pack on your model and give it a very gritty feel. My normal setting is 20 psi with Model Master at a normal thinning. If I thin it a little more then I can set the pressure down to 15 psi for real close fine work. If you don't have a pressure gauge then you should but one. Dixie Airbrush in New Orleans carries a lot of airbrush products and their prices seem very reasonable. I have never ordered from them so you might post to see if anyone has done business with them. They do have a website but I don't remember the exact address.
Posted by naplak on Wednesday, January 8, 2003 12:57 AM
I mix my paints with about 30% thinner... depending...
I usually use about 18 -20 psi for acrylics and enamels, and about 9 - 10psi for lacquers (like Alclad).
naplak Modeling:
http://www.naplak.com/modeling
www.naplak.com/modeling ... a free site for modelers www.scalehobby.com/forum/index.php ... a nice Modeling Forum
    July 2013
Posted by modelmaker66 on Monday, February 15, 2016 5:22 PM
15-20 lbs more or less
