Best Primer for Acryl
    May 2012
Posted by pilotjohn on Tuesday, July 31, 2012 10:22 PM
I gave my model two coats of MM acryl primer and let it sit for 3 days.  I then used Tamiya masking tape and painted and when I removed the tape, everything was good except for one section...  Maybe I didn't get enough primer on that section.
I have an Fw 190 curing with a rattle can white enamel primer just to see what the difference will be with the masking.
Q:  What is the "best" primer to use?
I have gotten several different types, but am wondering if one works better under acryls.  I think the primers mentioned (Mr. Surfacer, Tamiya, etc.) are all enamel.  That true?  Sorry for any repitition, but this is a bit frustrating.  We can go to Mars and we can't make an acryl paint that sticks to plastic..
John
    May 2011
Posted by AceHawkDriver on Tuesday, July 31, 2012 10:32 PM
Sounds more like that section had a contaminant on it like oil from your fingers etc.  From my understanding Model Master Acryls can easy to lift off.
The one primer I've used with great and predictible success every time is Tamiya's fine (gray) primer.  Its a rattlecan which is harder to control, but it gives a nice, even, smooth coat.  I've tried Model Master primer before but haven't had any luck with it for some reason.
Mr. Surfacer is nice and can give great results from what I've seen, but putting it through the airbrush was a chore.  I still haven't found a good primer:thinner ratio and get a lot of "cobwebs".
I routinely used Tamiya's primer under Tamiya paints, Model Master Enamels, and Vallejo acrylics without issue.  Haven't used Model Master Acryl very much though.
Hope it helps!
Peace through superior firepower.
Brian
    May 2012
Posted by pilotjohn on Tuesday, July 31, 2012 11:12 PM
Brian;
Thanks.  I thought I had given it a soak before starting, but I need to scrub it down a bit before the primer coat.
I don't like those cans as I can never seem to get a smooth finish.  I can't bring myself to use them indoors in the hobby room and outside is always got "stuff" moving around in the air.  I saw the FSM video on decanting spray paint, so I may give that a try and see how that goes with an airbrush.
It stinks to get your masking right and get a good job and then peels the other color that you masked and then you go back and forth.  I am going to try a drafting type tape next.  Can't think of a tape with less tack than that.  Interestingly, I asked Testors about it, and they recommended using wet paper to do the mask.  Said you can only do sections at a time before it dries, but it might be worth a try.  Seems a little "out there" though.  Not sure how you get wet paper to stick to curves and the like?
John
    July 2004
Posted by stikpusher on Tuesday, July 31, 2012 11:33 PM
Well I cant say it is the "best" primer, because I really do not use any others, but I do like Humbrol's primer in their enamel line in the small tin. Stir it thoroughly, mix with your preferred enamel airbrush thinner (I prefer Model Master Airbrush Thinner) to the appropriate mix for airbrushing, and apply it with your airbrush. Works great for me every time.
But yes it is frustrating to have to prime with an enamel in order to give the acrylic something to stick to and not have to worry about the MM Acryl paint lifting off when masks are removed. Sort of defeats the whole reason for going acrylic regarding chemicals and clean up and all that nonsense.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    May 2012
Posted by pilotjohn on Wednesday, August 1, 2012 7:34 PM
So for the extra credit part of the program; How do you fix this mid-build?  I am shaking in my boots about taping over the just painted areas to put the other color/coat back on and then when I take the tape off I have just peeled the newly painted section and I am in a circle so to speak.
John
    July 2004
Posted by stikpusher on Wednesday, August 1, 2012 7:45 PM
Well you can either mask off the newly painted area once it has had time to dry and cure, and airbrush again, running the risk of the same thing happening when you remove the new masking. Or you can touch up with a fine paint brush by hand.
       - Plankton
LSM
    April 2005
Posted by wing_nut on Wednesday, August 1, 2012 7:45 PM
99 times out of 100 when I do prime it is with Mr. Surfacer 1200.  Thinner with lacquer thinner it sprays just fine without any AB problems at all.  Has some nice bite to it so it has never peeled.
Marc
    August 2007
Posted by DUSTER on Friday, August 3, 2012 12:45 AM
Sounds like (as noted by Brian) a surface contamination problem in this case.
I have used MM acryal for a while and so far not had your situation occur. [note:  it is not my  skill so much as my dumb luck]
I use  Tamiya Tape and give at least 24 hours between colors.
That said, the use of Post-it notes  or the wet paper trick can also give you a quick mask for spot touch ups.
For primer I have used what the others have used, including  automobile primer and have Alclad II primer for a future project.
So don't give up keep trying different combinations to find your "go to" combination.
spray lightly and smoothly and may your runs be only in baseball.
Steve
