AirBrushing Trick
    April 2010
AirBrushing Trick
Posted by Nightwind on Wednesday, August 1, 2012 5:26 PM
Greetings I have a question about airbrushing. I have seen some fantastic paint jobs my question is how do you do those fine  lines making everything look so perfect I have a double action an a single action airbrush. I have for the life of me try to do those very same lines I had no luck whatsoever. There has to be a trick to this and I have not learned yet. Do you have to buy different nozzles in order to get that type of line. I look forward to your answer. Hoping to learn something new. Thank you one and all. Tim
    August 2005
Posted by Phil_H on Wednesday, August 1, 2012 6:24 PM
Thin lines are achieved through a combination of very thin paint, low air pressure, very close distance (in the order of 5-10mm) and lots of practice..  Big Smile
    August 2007
Posted by DUSTER on Wednesday, August 1, 2012 7:58 PM
Phil_H
Your are right,Phil Can't ever have too much practice, but even then I have to blot the bloops  more often than not
Good luck on your quest Tim it will come around faster than you think
Steve
