uuuuhm what?!?!
    April 2011
uuuuhm what?!?!
Posted by tcepilot on Sunday, August 5, 2012 5:32 PM
Why does my airbrush leak paint out like this? ( I use the paint cup)
-tcepilot
 just make a gif here
    October 2008
Posted by Don Wheeler on Sunday, August 5, 2012 6:35 PM
I would have thought you could see where it was coming from before it got that bad.  Are you tipping the cup when it's full of paint?
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    April 2011
Posted by tcepilot on Sunday, August 5, 2012 9:19 PM
a bit, but I can't tell where it's coming from
-tcepilot
    October 2008
Posted by Don Wheeler on Sunday, August 5, 2012 9:53 PM
The only thing I can think of is that maybe you are shooting downward and there is a leak from the cup.  You need to experiment.  Try plain water and hold the airbrush level.  If that's OK, try pointing it down.
There may be a poor seal between the cup and the brush.  You might try spraying from a bottle to see if it still does it.
Don
    April 2011
Posted by tcepilot on Sunday, August 5, 2012 9:57 PM
Ok I will try it
-tcepilot
    April 2011
Posted by tcepilot on Sunday, August 5, 2012 9:58 PM
Does anyone know if the Paasche TG is good for MM enamels?
-tcepilot
    October 2008
Posted by Don Wheeler on Sunday, August 5, 2012 10:22 PM
Most airbrushes will spray enamels fine, and the Talon is no exception.
Don
    August 2007
Posted by DUSTER on Monday, August 6, 2012 10:14 AM
tcepilot you many still have a bit of smuch (an air brush tech. term  ) in the passageways.
Try to take it apart and give it a deep cleaning with  lacquer thinner and small brushs. I carefully use dental brushs (@ $ store) and gently swab out the openings. don't forget the airways as well as the paint ways -the cup and the air brush's.
 This isn't brain surgery but you have to treat it like a delicate operation- no hammers allowed  .
As you reassemble  keep aware of how parts go together, they should fit easily and come together easily- if you have to push  or twist it hard, then something is wrong- back off and carefully try again.
I'm sure you know all of this but sometimes you fool yourself into  the brush is clean and it isn't (dont ask how I know   ).
Then as the others stated check you painting technique - tipping the brush etc.
Good Luck and keep up your good work - your Vietnam Air War GB is looking  fine .
Steve
