Paint Booth Plans?
Paint Booth Plans?
Posted by Wingman_kz on Thursday, March 13, 2003 11:59 AM
I wanted to ask if anyone could tell me where I might find plans for building a paint booth. I live in an apartment and don't have ready access to any other place to paint. I've found several different ones online and in magazine adds but I'm afraid they are a bit out of my price range. Any help would be appreciated.
    January 2003
Posted by JChurch on Thursday, March 13, 2003 12:23 PM
Hey Wingman try this:
Go to your local Home renovation shop, ie: Home depot, Revy, Ace hardware. and pick yourself up a cheap stovetop exhaust fan, it already has on/off switches as well as a light and filter, just build yourself a box around it to suit your scale, then add some ducting to vent it outside, or use on your balconey, just be warry of wind direction so you don't pass it on to your neighbours, they get upset about that sort of thing.[:0]
It might not be pretty, but it works
Madd DawgCool [8D]
Your not going to leave it like that are you?
Posted by naplak on Thursday, March 13, 2003 12:33 PM
Another way to go... I have a page on building a simple hood that i use...
http://www.naplak.com/modeling/tips/painting_hood.htm
naplak
www.naplak.com/modeling ... a free site for modelers www.scalehobby.com/forum/index.php ... a nice Modeling Forum
Posted by dariencharlie on Thursday, March 13, 2003 5:16 PM
The December 2000 issue of FSM has an article, "Make your own spray booth", which you can order a back copy off the site here; unless I got the last copy! Smile [:)].
Posted by Anonymous on Thursday, March 13, 2003 7:42 PM
Check out my website........and hit the workbench section. I have some pics of my spray booth and some verbage to go with it.
It's pretty simple..........2x3's and 3/8" Plywood, a fan, ducting and some lights.
http://www.kithobbyist.com/bluenosers352nd
Posted by Anonymous on Friday, March 14, 2003 8:09 AM
Thanks for posting those pictures.
I was just wondering if the placement of the exhaust fan affects anything? Is it better to mount it on the side, the back, the top? What advantages or disadvantages would there be for each scenario?
Thanks.
Ray
Posted by Anonymous on Friday, March 14, 2003 11:30 AM
Ray, here's my thoughts (collected from reading lots of other discussions on this):
1. Top mount - probably most common. Some people say the downside to this is that particles that get trapped in the filter (above your model) can get dislodged and fall into your paint. It also seems counter intuitive to try to pull paint particles against gravity...
2. Back/side mount - creates a cross draft of flow across the surface of the model.
3. Bottom mount - creates a 'down draft' that uses gravity. I built mine this way, but I have no idea whether or not it's really better than the others or not.
I don't really know if it matters all that much. The biggest thing I can see is to get the right sized fan. Too small won't clear the fumes/particles fast enough. Too much will draw too much outside air/dust into the booth.
PS. I built my booth out of heavy corrugated plastic (looks like cardboard, but is actually white plastic) glued together with a hot glue gun. Very cheap and the end result works quite well. Send me an email if you'd like more info...
M.
Posted by Anonymous on Friday, March 14, 2003 3:55 PM
Here's another tip to check out over on the Scale Auto web site.
http://www.scaleautomag.com/sca/features/tips/tip23.html
M.
Posted by Wingman_kz on Friday, March 14, 2003 4:15 PM
hmmm...
i wrote a reply but it got lost somewhere along the way and now it's time for work so i'll keep this short. thanks for all the input folks, it's been a big help. now it's time to buy some materials and get to busy. i'll let you know how it turns out.
thanks again
Wingman
(aka...Tony)
