Um, what did i do wrong?
    March 2010
Posted by Scorpiomikey on Wednesday, August 22, 2012 12:50 AM
I sprayed my 100P tonight. Not happy with the results. The paint doesnt seem to want to stick in the panel lines. Im not sure what im doing wrong. I washed the resin body (Warm water, mild detergent) wiped off any water droplets with a paper towel then left to dry. Primed with Tamiya Fine Surface Prime (L), let that dry, then sprayed with Tamiya TS-44.
Im concerned about the bubbling of the paint. Im not sure why its doing it. Any suggestions?
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    July 2004
Posted by stikpusher on Wednesday, August 22, 2012 12:54 AM
How long did you let the primer dry? Minutes? Hours? Days?
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    March 2010
Posted by Scorpiomikey on Wednesday, August 22, 2012 1:06 AM
About an hour. Its never presented a problem in the past. Other kits ive used it on ive sprayed over it within 10 minutes with no consequences.
My signature
    December 2006
Posted by Fly-n-hi on Wednesday, August 22, 2012 10:53 AM
Did you shake the TS-44 really well?  Did you let the can sit in warm water for a few minutes?
Posted by VanceCrozier on Wednesday, August 22, 2012 11:24 AM
paint avoiding the panel lines sounds like there may still be something "release-agent-y" in there - did the primer do the same thing there??
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    March 2010
Posted by Scorpiomikey on Wednesday, August 22, 2012 3:09 PM
Primer sort of did the same thing. I would have thought a decent scrub with soapy water and a toothbrush would have gotten it all. Is there anything i can do to fix it now?
My signature
    August 2007
Posted by DUSTER on Wednesday, August 22, 2012 10:09 PM
 ............  ................. Idea! -in two parts:
 1] a light coat of clear lacquer to "mask" the mystery stuff  then after drying; repaint
and /or
2] strip the paint, re wash, re prime, re paint .
sorry best I can come up with; Good Luck
Steve
    March 2010
Posted by Scorpiomikey on Wednesday, August 22, 2012 10:11 PM
Cheers duster. Ill sand it back a bit first just to try and preserve some of the detail.
My signature
    March 2012
Posted by 01JeepXJ on Saturday, August 25, 2012 11:48 PM
As primarily a model car builder, I recommend(you ain't gonna want to hear this) strip the paint & wash the plane.
Soak in Westleys Bleech White-white wall tire cleaner at least over night. Clorox bleach works also. Wash with warm Dawn dish detergent water. Use soft toothbrush to scrub all the indentions. Rinse WELL. Wipe down with alcohol/dry & do the process again.
Others will probably have more ideas.
Never try to teach a pig to sing. It's a waste of time and only annoys the pig.
    March 2010
Posted by Scorpiomikey on Sunday, August 26, 2012 12:41 AM
Cheers jeep. i didnt know bleach stripped paint. Does it damage resin? it was a really expensive kit and i dont want to damage it.
My signature
    March 2007
Posted by bondoman on Sunday, August 26, 2012 12:51 AM
usually you get that effect when the paint is thinned out too much.
    March 2010
Posted by Scorpiomikey on Sunday, August 26, 2012 1:54 AM
Its all tamiya rattlecan.
My signature
    March 2012
Posted by 01JeepXJ on Sunday, August 26, 2012 2:31 AM
I don't know if bleach will strip paint. Resin is a different material than plastic. DO NOT put resin in brake fluid to strip paint. I'm told this will nearly melt resin. Possibly Purple Power or similair will take the paint off.
Bleech White or bleach will remove the mold release agent from resin parts. This release agent acts like grease when it comes resisting paint. This could be your problem-the release agent used on the resin.
Do the instructions say anything about cleaning the body and/or what with?
Try to get more input on what to strip the paint with. Resin kits/parts are good but usually pricey.
    March 2010
Posted by Scorpiomikey on Sunday, August 26, 2012 2:44 AM
Ah, cheers Jeep. The instructions are pretty limited. Its a planet models kit. It just says to wash the parts in soapy water. which i did.
I was going to get some ELO paint stripper. And ive heard simple green is good for stripping paint. But im not sure if they work with resin.
My signature
