I played with it for a little while,,,,,,,,and then gave up on it
the reason was simple
anyone know how many drops of any color to start with to be working in the right ball park to a modeling color,,,,,say,,,,Haze Gray for a ship?
if you do, then you can start with a close color and fine tune it with that tool
BUT
if you can guess the starting point that close, and are able to create a "very close Haze Gray chip" on your monitor,,,,,,,you are already good enough to have it done beforehand with actual paint and a Chip from a Paint Guide
no matter how close I could possible get it,,,,,,it still sits on the monitor, telling me that I need 14 drops of Golden paint one, and 12 of this, 7 of that,,,,,,,and there is no "Golden to model paint" drop converter to make paint with
now, if that software was able to be set up for 6 different paint lines, then the results could be made as paints
the other "converter" online works with chips, and paints,,,,so you can decide on a paint to use on a model
Rex
