QUOTE: Originally posted by Dimitris
I use Gunze acrylics. The problem is more evident on flat black.
No, Ididn't prime. What color works best as a primer? Silver?
Gunze acrylics should be try within a few hours at the most, even if you apply a thick layer of paint with a brush.
No, you best use a primer.
There are many different primers out there, some even use automotive primers for cars. Gunze, Tamiya, etc they all make their own primers which tend to be a bit on the pricy side.
Many will tell you that plastic models don't need to be primed, but you will get a better end-result of you do.
As the other recommended try to get hold of some surgical gloves or similar and try to handle the parts as little as possible and topcoat between paint layers.
Nothing else I can think of right now.
