Air Brush PSI Setting
    May 2005
Posted by IceDragon122 on Sunday, October 7, 2012 3:46 PM
Hi All!
I recent came back to the hobby after a approx 5 year hiatus.
I recently bought an air compressor from TCP Global and it has a air pressure regulator. I never had one of these....always used a testors mini blue compressor.
Anyways i figured out how to set the gauge. My question is what pressure should i shoot paint through?
For reference, i'm using a badger 150, and using MM Acryl acrylic paint thinned with Golden airbrush thinner (to the consistency of milk).
I tried shooting it at about 10-12 PSI -- my model came out a bit rough but overall very nice -- still cant figure out how to upload picts yet
So anyways i just wanted to get a sense or feel for what you guys use.
--Thx!
--Brian
    October 2008
Posted by Don Wheeler on Sunday, October 7, 2012 4:05 PM
12 psi is kind of low to get good atomization with a siphon airbrush like the 150, especially if you are feeding from a bottle.  I generally use 15 to 25psi.  The best bet is to experiment on some scrap and see what works best for you.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    March 2010
Posted by ACESES5 on Sunday, October 7, 2012 6:48 PM
I use 15 lbs of pressure for my Paasche H air brush I spray Tamyia, Model Master and Poly Scale works great         ACESES5                ON BENCH M50A1 ONTOS
    May 2005
Posted by IceDragon122 on Monday, October 8, 2012 7:16 PM
Thx guys for your help -- i will look into increasing my air pressure a tad
--Brian
Posted by Don Stauffer on Wednesday, October 10, 2012 8:57 AM
I find increasing pressure may actually increase roughness.  I usually use 15 psi, but I don't think 2 or 3 pounds will make much difference. If you go very high- 20 or so, the paint will tend to dry out more before it hits the surface.  Also, increasing the pressure may make you back off aways from the surface, which also lets it dry more before it hits, increasing roughness again.  Also, too thin a coat promotes roughness.  The wetter the coat, the smoother and glossier it will get.  Also, more thinner creates a smoother surface- try thinning a bit more.
    September 2012
Posted by Tankster on Thursday, October 11, 2012 1:17 AM
I own a badger 155 anthem and I spray very  low for the fine detail work like camo lines and patches.  If the paint comes out a little rough at that setting you may need to thin it out a tad bit more and spray a little closer to the model.  Rough paint usually means that the paint is drying before it hits the model's surface  I use either 90% alcohol or odorless mineral spirits to thin with.
On The Bench: Dragon  1/35 Jagdtiger Henschel
On Deck: Dragon 1/35 Ferdinand
    February 2011
Posted by randypandy831 on Thursday, October 11, 2012 8:20 PM
pressure also depends on how thin your paint is. since your finish is coming out rough, you might be spraying from to far a distance. try spraying a little closer. some paints will come out a little rough though because they are very flat. a gloss coat will level it out. and also, MM acrylics are easy to over thin since they pretty thin from the bottle.
tamiya 1/48 P-47D $25 + shipping
tamiya 1/48 mosquito $20+ shipping
hobby boss 1/48 F-105G. wings and fuselage cut from sprue. $40+ shipping.
