How safe is Tamiya paint to brush?
    February 2011
Posted by GreySnake on Wednesday, October 17, 2012 7:21 PM
Hey guys! I'm just wondering if Tamiya paint is safe to brush without a respirator? I know when air brushing you should always use a respirator. But is the paint stable enough to use while brush painting without having to worry? I've done a lot of searching and really can't come up with anything solid. Thanks guys!
    July 2004
Posted by stikpusher on Wednesday, October 17, 2012 7:48 PM
Tamiya paint is fine regarding fumes/odor for hand brushing. But it really sucks to hand brush. It dries way too quick and does not hand brush well. You can play with it by adding their thinner or distilled water to improve its' hand brushing properties, but it is very much a trial and error process.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    February 2011
Posted by GreySnake on Wednesday, October 17, 2012 8:18 PM
Thank you! That puts my mind at ease  finally. Ever sense one of my family members died from lung cancer. I've been paranoid about the chemicals that are used in modeling.
Regarding brush painting Tamiya. I've always had good luck painting small parts with it tools etc. But yeah it is bad for larger areas.
Thanks again! Now I'm finally working up the nerve to hit the bench after a year away!
    August 2005
Posted by Phil_H on Wednesday, October 17, 2012 8:23 PM
Add one part X-20A thinner to three parts paint and it will completely transform its brushing properties.
The usual rules still apply though - avoid brushing over dry/partially dry areas to prevent it pulling up. If recoating is required, let it cure overnight before doing so.
    November 2008
Posted by plasticjunkie on Friday, October 19, 2012 9:10 PM
Dont like how Tamiya paint brushes. Have been modeling and painting & spraying without a mask for nearly 47 years so I guess I should be dead! Surprise
 GIFMaker.org_jy_Ayj_O
    April 2009
Posted by Cadet Chuck on Friday, October 19, 2012 9:17 PM
If you're spraying, wear a respirator.  If you're brushing, especially acrylics, no sweat/
    July 2004
Posted by stikpusher on Monday, October 22, 2012 2:47 PM
We are all born to die Professor ;-)
       - Plankton
LSM
