stripping off tamiya acrylics
    August 2009
Posted by rgriffs on Saturday, October 27, 2012 2:41 PM
can someone suggest a method of stripping off tamiya paint, it was sprayed 4 days ago, but i don't like the appearance of it. ( it was chrome silver ). i need stuff that is available in the u.k. sorry to be specific, but trade names are different over here.
    July 2003
Posted by Kugai on Saturday, October 27, 2012 2:46 PM
If it's airbrushed acrylics, rubbing alcohol should work.
http://i712.photobucket.com/albums/ww122/randysmodels/No%20After%20Market%20Build%20Group/Group%20Badge/GBbadge2.jpghttp://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    January 2012
Posted by PANZER826 on Saturday, October 27, 2012 3:20 PM
If rubbing alcohol doesn't work I have also used ammonia.  If that won't work Easy Off oven cleaner definately will.  Spray it on and put the model in a zip strip plastic bag overnight.  Next morning just wash it off with a toothbrush.  Just wear a mask and gloves with the oven cleaner as the fumes are nasty.
    January 2005
Posted by Watchmann on Saturday, October 27, 2012 3:48 PM
Windex (ammonia) will take it off in seconds.
    August 2005
Posted by Phil_H on Saturday, October 27, 2012 7:43 PM
If you are talking about the regular bottled acrylics (not the spray cans), it doesn't get much simpler then plain old methylated spirits (aka denatured alcohol).
    August 2009
Posted by rgriffs on Sunday, October 28, 2012 5:40 AM
thanks for your replies, tried Mr muscle oven cleaner on a trial piece, it worked brilliantly. looks like new.
Dre
    June 2007
Posted by Dre on Tuesday, October 30, 2012 5:14 PM
Simple Green does a great job on removing Tamiya acrylics, but sometimes you have to scrub the parts a little with an old toothbrush to all the paint.   Household bleach can also strip Tamiya acrylics but it takes a lot longer to work.
    December 2010
Posted by 1943Mike on Sunday, December 23, 2012 2:11 PM
Here's another vote for Simple Green.
This morning I took a couple of plastic baggies and put in the deck pieces from Revell's 1/96 Cutty Sark which I'd painted with a flat black then, after curing for 24 hours, airbrushed a brown color (which I ended up not liking) over the black. I added Simple Green enough to make sure all painted surfaces were covered. I let it sit about an hour (much more and the Simple Green might eat through the baggie), took out the deck pieces and, with an old tootbrush, easily removed all but a minute amount of both layers of paint.
Since Simple Green is an eco-friendly, non-toxic cleaner, I much prefer using it to oven cleaner.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    December 2010
Posted by 1943Mike on Sunday, December 23, 2012 2:15 PM
Oops! I should have mentioned that I had airbrushed Pollyscale and not Tamiya acrylics on the deck pieces of my Cutty Sark Embarrassed
Hector Berlioz
