Paasche H
    August 2012
Paasche H
Posted by JMorgan on Friday, November 2, 2012 3:36 AM
Does anyone know how to disassemble the needle on this brush?
    July 2010
Posted by Subhuman1 on Friday, November 2, 2012 4:22 AM
Howdy,
Unscrew the set screw, on the bottom of the brush, just under where the needle is mounted. Then grip the rear of the needle and the front of the needle at the same time and unscrew the cap from the needle, the needle will slide backwards out of the mount, and the air cap will come away once the two are unscrewed from each other.
 You don't need to completely remove the set screw, just back it out a couple of turns, the carpet monster really seems to find these quite tasty :)
    July 2008
Posted by Vit13 on Monday, November 5, 2012 11:47 AM
Hello ,
maybe this video could help you .
    December 2007
Posted by Wrinkledm on Wednesday, November 7, 2012 4:20 PM
If a little paint has worked its way around the base of the needle, the needle will stick tight and not want to budge from the airbrush. KYou may have to soak it a bit in thinner if that is the case.
